Old 11-04-2011, 10:33 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 #840 heads and 396 402 rotating assembly
3919840 square port heads magged and stock both dated A-22-9. One head has two small hairline cracks in the combustion chamber which will require two new seats and the one goes right above the seat and either will need to be ground out or pinned. Will sell the pair for $850.
I also have a balanced set of brand new hyperuetectic Keith Black closed chamber pistons that are standard bore 402 but can be used as 30 over 396 pistons as well. They are series #160 and have stock rods and are balanced to a standard 6223 steel crankshaft. 105CC closed chamber head will give you 9.5 to 1 and if you go with an open chamber 118CC it will drop down to 9 to 1. Will sell the balanced rotating assembly for $600.
330-770-2517 for any questions or pictures needed.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
