Old 09-10-2011, 07:18 PM   #1
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Default Re: Questions about Cobra Jet 5.0
Jimmy Ronzello's Coyote motor at Indy.
ID:	9256   Click image for larger version
Steve Jackson
Old 09-10-2011, 07:28 PM   #2
201250
201250's Avatar
So I guess between Milan and Indy the throttle cable got taken off to pass tech?
201250 is offline   Reply With Quote
Old 09-10-2011, 11:55 PM   #3
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
The engines in post #1 and #7 are not legal in Stock.
Ford never built any 5.0 Coyote engines for Stock Eliminator.....only part number paper combos.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 09-12-2011, 10:04 AM   #4
Jesse Kershaw
Liked 122 Times in 11 Posts
The 2012 Cobra Jet engine is very similar to the stock Mustang GT engine combination. The most notable difference is the pistons that add compression and the cams.
The intent of the Cobra Jet's with the 4.6L 3v and the 5.0L was to make it affordable for racers to build street cars into competitive NHRA Stockers. Even the 3v cylinder heads CNC ported are less money than getting a "valve job" on many vintage set of heads.
NHRA tech has told me that in general they will accept a replacement piston that is slightly less compression BUT that it must be submitted as an offical replacement piston. A racer or engine builder can submit a stock 5.0L or 3v piston, or an Aluminator piston as a replacement for the Cobra Jet piston and ask for it to be approved.
The 5.0L and 4.6L Cobra Jet models are a great bargain for building a Stocker, especially starting from a street car.
Jesse Kershaw
Jesse Kershaw is offline   Reply With Quote
Old 09-12-2011, 10:44 AM   #5
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
What was the reason for making the changes to the pistons and cams? Why not just use the entire street motor if they are so similar?
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 09-12-2011, 02:22 PM   #6
Greg Hill
Liked 279 Times in 68 Posts
Andrew, I thought it would be obvious, to make things fairer for the rest of us.
Greg Hill 4171 STK
Old 09-12-2011, 03:04 PM   #7
Ed Wright
Ed Wright's Avatar
Yeah, that's the ticket.
Ed Wright 4156 SS/JA
Old 09-12-2011, 04:09 PM   #8
201250
201250's Avatar
I didn't know we could do that. WOW Can I send one of the Manley rods and have it approved also. Kdanner is right can I use the 6r80 trans as approved along with a beefed up 8.8 instead of the 9"?
Old 09-12-2011, 04:18 PM   #9
Andrew Hill
Of course, how could I miss that? It makes sense now.
3207 D/SA, C/ED
Old 09-12-2011, 04:50 PM   #10
BlueOval Ralph
Banned
Not sure Jesse can answer this, might have to ask someone else, just look at the SNAFU on the on the Blueprints sheets at NHRA! 3 years three screw ups! This was years screw up
2010 Specs
500 hp SS/S ENGINE WITH WHIPPLE S/C IS LISTED AS A 2 INTAKE VALVES 1 EXHAUST VALVE. SHOULD HAVE BEEN AA 4 VALVE MOTOR.
This was last year till just befor INDY.
Ralph
BlueOval Ralph is offline   Reply With Quote
