My 73 SD 455 came with 80psi pump spring. We put in the 60 for street/strip use. But, I figure the factory knew what they were doing when they went to the trouble of the 80 with the special larger distributor gear to prevent premature wear of the gear. The Super Duty used that high pressure pump overcome the centrifugal forces of the long throw crank at 6000+ when the SD's anticipated use was Stk/Super Stock racing is what I understood... Butler or Nunzi should know!
Good luck with that Pontiac! Norris |
#2 | |
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Brent, yep the sd455 did have more clearances than standard 455s for sure...
Ive run pontiac for 28 years and bracket race in florida so i race alot (year round) ive tried every pump available and what i use now has been the best for durability i use the melling pump with 60 lb spring but shim the spring with 1 or 2 hardened washers depending on bearing clearance (mine is loose).that was recomended to me by jim butler in tenn.my engine has been in the car for 3 seasons,i race 2 to 3 times a month i pulled it out after 2 seasons and the rods and mains looked like new and put it back in as is
scott fifield |
Liked 56 Times in 27 Posts
Brent,
I agree with Todd 100 % , you can't go wrong with the Mellings 540. That's all I have run for 10-12 years, save your money for other things... Good Luck with your project ...
Dave Ribeiro 1033 STK |
