07-11-2011, 04:57 PM | #1 |
Sponsor
Liked 965 Times in 63 Posts
Single channel O2
I'm looking for recommendations on a single channel O2 set up. My stocker has me frustrated, and I really think I'm out in left field fuel wise. My headers have a bung in each collector, so I'm equipped to install. Thoughts and recs would be appreciated. Thanks.
07-11-2011, 05:08 PM | #2 | |
Liked 389 Times in 168 Posts
Re: Single channel O2
Ed Wright 4156 SS/JA |
07-11-2011, 05:17 PM | #3 |
Liked 220 Times in 95 Posts
I've got the FAST unit with one sensor. I'm going to add the second one.
It records and plays back on it's own screen.
Floyd Staggs 787 SST Last edited by Floyd Staggs; 07-11-2011 at 05:48 PM. |
07-11-2011, 05:26 PM | #4 |
Liked 510 Times in 200 Posts
I used an Innovate LM-1 to tune my LT-1 Firebird. Didn't know squat about EFI when I built this car and the LM-1 was a big help....and easy to operate. Record a run and download to a laptop and look at the log......Very nice software to manipulate the run logs.
Greg Kelley could easily get you fixed up with a recorder .....http://www.motorsportsinnovations.com/ Handheld box/ set it on the passenger seat, push the button to record after doing a burnout and push it again at the end of the run. Disconnect the quick plug in cables and plug into laptop in trailer after the run... A local ET racer demo'ed it for me and I loved it...... P.S. Dan.... we once had a short conversation at E-Town....You still had the EFI LT-1 Firebird and said you were going to dump it in favor of a '69 Camaro.....Was a good move! I sold mine as well.....and I'm glad I did....
Rich Biebel S/C 1479 |
07-11-2011, 05:35 PM | #5 |
Dan, I had horrible luck with the innovate stuff. We now have a race pack on Dad's car and I have the accel unit on the camaro that ties into the DFI. Both work very well, however the Racepak is only useful if you already have a data logger. The accel has a stand alone gauge and will log RPM/Driveshaft RPM and AFR
Chad Rhodes 2113 I/SA |
07-11-2011, 06:19 PM | #6 |
These units will work whether the car is "carburetor or injected"?? Dont' laugh!
Greg Johnson 3123 STK |
07-11-2011, 07:01 PM | #7 |
Liked 1,079 Times in 282 Posts
Daytona Sensor has a really nice setup.
If you just want a digital readout you can easily see, the NGK Powerdex comes with a box that has the digital display that is easily read while driving, the sensor, the harness, and an output that will work with most data loggers.
Alan Roehrich 212A G/S |
07-11-2011, 07:12 PM | #8 |
Liked 67 Times in 14 Posts
Racepak sportsman with a sensor in each collector. You can also weld a bung on each header tube and move them around every run for individual tube readings. With as many runs as you make in a year you should have it dialed in quickly.
Racepak Software and USB card is easy, no fuss use and no special computer skill required. -Matt Welker |
07-11-2011, 07:14 PM | #9 |
Liked 61 Times in 8 Posts
I have the FAST dual channel on my car. It is easy to use but the numbers change so fast on playback you have to average out between he numbers. Best bet is go the racepak route. Cant go wrong.
Ken Etter 7375 STK/5 SS |
07-11-2011, 07:24 PM | #10 |
Floyd, your using the XFI system? I bought the second FAST O2 for mine after fighting an injector problem through most of 2010, on the opposite side from the one O2 sensor. The second one does not read the same as the one that comes with the XFI system. Not even the same brand sensor. Very dissapointed. My two only agree around 12-1. If you have a carb, not the XFI, their stand alone wide band records air/ fuel versus time, not RPM. Air/fuel versus RPM is much more useful for tuning. I have seen way too many problems with the innovate deal. I personally wouldn't use it.
