Old 07-06-2011, 08:11 PM   #1
BLIND MULE
BLIND MULE's Avatar
Default Re: trailer tires??????
Not to sound like a broke record but 16's will be a lot better if you can go that route! My buddy had a triple axle Pace that was not overloaded and he kept blowing tires ALOT and he didn't pull the trailer much at all and it had me puzzled???? Come to find out he was only running 32 psi in his tires and it was killing the side walls ! I told him to put 60 in them and the blowout's stopped so make sure you have plenty air in them I run 80psi in my 16's and so far have had to put on one set in ten years and I know my trailer is over weight just lucky I guess. But if all the tires are the same age if you have one blow out then the rest will follow just like light bulbs so go ahead and replace them all.
BLIND MULE is offline   Reply With Quote
