#1 | |
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
Liked 53 Times in 25 Posts
There hard to find Gary.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Yeah, sad but true I guess since M/T no longer makes them. I still have one descent 20X8 inch slick, but after it wears out, I'm resigned to DOT slicks, but I suppose with them I won't have to change them at the track, since those slicks don't hold air well for more than a couple of hours. Hopefully M/T's DOT slicks have descent bite, and can run with nearly 20-24psi of air pressure? Dennis, you have any insite on that?
Liked 780 Times in 194 Posts
Billy Nees -
How about spitting out two or three of those $5K combinations to whet everybody's curiosity?? |
Liked 7,756 Times in 1,741 Posts
Dwight, I'll spit out some "nuggets" if you'll do the same.
No problem. Just be aware that my offerings will probably be of the manually-shifted variety. We might have to put some limits on this to keep people from being overwhelmed, so how about starting with three each and the three all have to be different manufacturers? Considering the extra expense of the stuff required to make a stick shift car reliable, I might have to bump the budget to $7500 for those entries, but I can throw out some automatic cars, too.
Liked 13 Times in 9 Posts
Since Billy' caveat was that the body was not included in the $5K, I'd say there's a bunch of good candidates out there. It's been discussed before, but take a look at the Chevy Cobalt. These things run mid-low 16's showroom stock and 200-300# heavy (2830 min in DF/S, pretty sure I scaled ours at over 3000# at Rockingham a few years back, before we traded it in on a real car), and I'm sure there's plenty of junk to take out of them. Tires, fuel, weight, and let it eat...
#8 | |
No I never tried them I found a new set of slicks at a speed shop in tenn last set they had. So as long as my son does need them for his car I am good for both cars for now. If you get any info on them let me know.
Polhill told me that Avon (a sister company to M/T) makes a 19.5" road race tire.
Gary - I've run my tires down around 13psi with much more success. We tried higher pressure, but it wasn't consistent. With my "big boy" 22x8-13's, it likes 12psi. Bigger tire with a smaller rim actually gives it some sidewall to work with.
#10 | |
With the low sidewall that the 20x6x14's, and 20x8x14's have, I'd be nervous to run that low of air pressure. However, running with 20psi, I've carded (with a decent burnout) 1.96-1.98 60fts, which is great for my car...I guess I could next try 18psi, but w/o tubes in my tires, I'll be leery of that low of a pressure? I'm glad to know it works with the 22's, I'll have to keep that in mind if/when I make the switch to the 22x8x14 dot's....thanks for the tip Michael....
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 07-01-2011 at 03:58 AM. |
