Old 06-17-2011, 01:26 PM   #1
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: Where are the lower class cars?
No altitude factor (the 4-cylinder is massively effected by the altitude. I was almost half a second slower at Bristol than even Numidia!) and unrealistic weight breaks (225 lbs heavy for DF/S, 400 light for EF/S) makes it an impossibility for me.
Old 06-17-2011, 01:48 PM   #2
Liked 5,124 Times in 1,953 Posts
Lots of reasons, Dwight. Most of them attributable to NHRA policies.
I'll give you one, but I'd like to hear other's opinions.
Class money...non-existent . Many lower class racers depended on it to help offset travel and entry expenses.
Old 06-17-2011, 02:01 PM   #3
Question Re: Where are the lower class cars?
Mark - Class money is the same for every class - that being said if you had 5 in a lower class only one would benefit from the class money for expenses and entries - so they ( the other four ) would still not be able to afford being there .....Or is it that you would like to reopen the single class deal again ?
Old 06-17-2011, 02:50 PM   #4
Jacko,
Yes it is , but if you can afford a quarter million operation, you don't worry about a little bit of class money.
The reason there were singles in class was not the racer's fault. There were just too many factors that kept people from building for the lower / slower classes.
What they did about was just a band aid for what they created.
That being said, if you can qualify no.1 , you should be able to win a combo class about anywhere.
You just don't necessarily need new slicks every month, twice the pistons, rods, rings, ceramic bottom lifters, etc.
Oh, and sorry I disparaged your Homies today and got your dander up!
Old 06-17-2011, 03:33 PM   #5
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
It's a lot of things but the bottom line is if you can afford to build a 'new' factory car then you have the money to race it. And if you have spent the time and money to build one then you are going to race it. Most new cars fit in the upper classes and are fast. Hence top qualifiers.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 06-17-2011, 03:43 PM   #6
Mark - My dander is fine ..........And as you know I raced lower class cars for almost thirty years so I fully understand but its not the NHRA's fault either that racers started liking fast ( as in speed ) cars .And you're right - a slow class car can easily win the combo deal along with the pewter Wally and whatever money .
One last thing - a racer can run a late model LT1 FI combo in A - B - C - D for a lot less than your quarter mill budget . Just ask Santangelo or Simmons who are competing this weekend at Bristol .
Old 06-17-2011, 03:54 PM   #7
Billy Nees
Liked 7,742 Times in 1,740 Posts
Little cars don't like Bristol.
Billy Nees 1188 STK, SS
Old 06-17-2011, 05:00 PM   #8
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: Where are the lower class cars?
Billy ,
You are dead-on , heat & no - factor for hauling all that weight ..
Slower & Heavy cars don't like the Mountain ... Good luck to everyone.
Dave Ribeiro 1033 STK
Old 06-18-2011, 08:37 AM   #9
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
The air is always bad at Bristol. Been that way forever. No money is why Im not there.
Bob Bender 144 O/SA
Old 06-18-2011, 12:48 AM   #10
GarysZ24
GarysZ24's Avatar
Liked 238 Times in 94 Posts
Angry Re: Where are the lower class cars?
Jack, I just found out that last years altitude correction factor was changed to emulate Competition Eliminators factor. If that's truly the case, then unless/until I come up with 5g's to upgrade my engine and change my cam to one with more duration, I may never run a altitude race at an NHRA event again, because my car won't run the number...if I was home, then I'd check the corrected index for DF/S and compare it to what it was last year (after NHRA's wonderful .3 reduction from 2009's factor). They're the ones choosing to make it harder for people like me who only ran .2-.4 under the index to be competitive nowadays, and this move just went over the top!
Well, thanks to IHRA, at least I have options for a couple of former NHRA altitude tracks...Salt Lake City, and Tucson!!!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
