Liked 880 Times in 311 Posts
Larry,
Did you notice something about that chart.... All the different strokes only have a .75 ratio spread between the bottom and top weight. I was way over the suggested start line ratio when I was running a PG in my car. I would say this is just a get started suggested number. I put a 1.76 in place of my 1.98 as an experiment to keep from hitting an index. It worked, my ET dropped .15... Made the 60's way slower. That was a 12.53 over all to a 11.14 in a 3175 lb car. I think the % drop in 1-2 shift made more difference than the start line ratio. It got in high gear too far down track and didn't let the converter work. A long, long time ago a person that was on top of things told me to pick the tire/rear gear for the desired MPH and the tranny low for the launch ratio. With today's converters I think 2 more factors should be considered. The torque converter ratio and the gear drop % go hand in hand.
Adger Smith (Former SS) |
Liked 4 Times in 2 Posts
Hi
Is there a recomendation for 3 speeds also? M.Lind |
Low! :~)
