Old 06-07-2011, 08:04 PM   #1
Winklovic
Winklovic's Avatar
Liked 29 Times in 8 Posts
Default Re: Jackstands, Please Use Them
This happened here just yesterday. It's always a good idea to have help when doing heavy lifting.
http://www.winnipegfreepress.com/bre...123336218.html
Charleswood man dies after backyard mishap
By: Staff Writer
Posted: 06/7/2011 7:50 AM
WINNIPEG - A 57-year-old Charleswood man has died from injuries he sustained after a rock slab fell on him Monday evening.
The man was performing yard work around 7 p.m. Monday and appears to have been moving a heavy object, possibly a piece of concrete, when he fell and became pinned underwater in a pond in his backyard, police said.
Family discovered the man later. He was taken to hospital in critical condition, but died Tuesday.
The man's name has not been released. Foul play is not suspected.
Brent Mazur
Winnipeg, Manitoba
Winklovic is offline   Reply With Quote
Old 06-07-2011, 10:32 PM   #2
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Very good safety message! I would only add, support the vehicle good enough to do the job....then double that and your ready to go to work. I use the jack stands with the floor jack in place. Place the jack stands, then lower the car till the stands make contact and are loaded and leave the floor jack in place. Also, do perodic assessment of the jack position and loading. You can use more than four stands, no rule aginst that. Sorry to here about everyones misfortune. One other side note: when you work alone, keep a cell or portable phone in your pocket....that's what I do...and like the jack stands, hope you never need it! My 35 years of race car fabrication as well as 25 years as a professional firefighter working on heavy rescue squads and ladder truck companies. I have learned from my mistakes as well as others.
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 06-07-2011, 10:46 PM   #3
Jim Bailey
Liked 584 Times in 94 Posts
Thumbs up Re: Jackstands, Please Use Them
An other helpful hint. Quite often (Always) our pit area is in grass. Take the time to weld a disk, or square on the bottom of your jack stands so they can't sink into the dirt. This works very well and can save you a bunch of grief. JB
Jim Bailey is offline   Reply With Quote
Old 06-08-2011, 08:17 AM   #4
69javman
My uncle and I were working on his '32 just a couple of weekends ago. We were doing some adjustment of the brake pedal pushrod which is under the car. After about 5 adjustments and then test drives, we were getting pretty sick of jacking the car up and putting the stands in place- then taking it down. You know the routine. On the sixth try, while jacking the car from the side it just slipped off the jack. Bang!! Just like that. We just looked at each other. Luckily no damage to either of us or the car, but it happens. Gravity wins.
69javman is offline   Reply With Quote
Old 06-08-2011, 10:42 PM   #5
bigshow2966
Liked 181 Times in 56 Posts
Unhappy Re: Jackstands, Please Use Them
I can't believe the number of people I've seen in the last 2 trips to the track either working under cars on a jack or warming them up in gear on just a hydraulic jack. Scares me and I'm reasonably fearless.
bigshow2966 is offline   Reply With Quote
Old 06-08-2011, 10:55 PM   #6
Bill Harris
Liked 26 Times in 13 Posts
B.S.!!! These pictures show very well that jackstands are just an annoyance and take too much time and effort to perform simple maintenance procedures. Bunch of pu$$ies.
http://www.swapmeetdave.com/Humor/Wo.../ProppedUp.htm
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 06-09-2011, 12:24 AM   #7
Smallbloc
See a lot of that , people just get lazy.
Smallbloc is offline   Reply With Quote
Old 06-09-2011, 10:50 AM   #8
FLEMING
Liked 55 Times in 26 Posts
And be sure to use GOOD jackstands.. I recieved some cheapies for christmas and later on that next spring I was in the shop I rented with some other guys by myself.. Had my car jacked up tires off and was using those new jackstands.. I got from under the car to go get a wrench I forgot and about 3 seconds after I got clear the car fell all the way to the ground, one of the welds on the jackstands failed and it just rolled over to the side.. The garage floor was perfectly flat concrete with no imperfections.. I would have died for sure because I was by myself and no one knew I was there... from that day on I use oversized jackstands and I am still "leary" of getting under a car sometimes....
FLEMING is offline   Reply With Quote
