Liked 140 Times in 51 Posts
Chev Buick,mustangs ,brand not the biggest concern.Was thinking of starting in stock and if i wanted to go faster change engine etc and go to superstock down the road.Not interested in the newer CJ"s or Mopars for $$$$reasons.Thanks
Kevin |
78-83 Chevrolet Malibu. Still cheap to buy. You should be able to get by in the lower classes in SS on a small tire.
any third or fourth gen F-body
Chad Rhodes 2113 I/SA |
My vote would be the GM G-Body's. You have the Malibu's the Grand National and the Olds Cutlass. They are cheap and have ton's of bolt on parts that work.
Alan Warman STK 4107 |
Liked 5 Times in 3 Posts
My Cutlass with just a bar & belts will run either stock or super stock IHRA . You would need to dig in the engine to make it run NHRA SS
Liked 4 Times in 4 Posts
1st Gen Camaro with a well built 427 will fit both classes also a lot of front wheel drive cars will double up to.
JimR
Jim Rountree |
Liked 7 Times in 5 Posts
Kevin My 95 Trans Am can run both stock and Superstock the way it sits and is under both indexes.. The price is right . Mike
'69 AMX 290 cu in 225 HP; ran it in M/S on 13.15 index, went 12.15, won two events.
Changed cam to .700 lift roller, massaged heads, Edelbrock "Torker" intake, "Quikfuel" 3310 Holley, 10.5" M/T's; run SS/M on 11.90 index, goes 10.60s in good air, won one event, so far. Almost always slowest car in eliminator, we leave first with very good driver. |
any new cj ford or DP will be just fine tighten them lugs
