Old 05-07-2011, 08:24 PM   #1
HEADSUP113
Default Oil pressure
Sbc 434 new engine 20/50 brad penn oil , what should be the max oil pressure cold ? 80 psi seems high to me. Any thoughts
HEADSUP113 is offline   Reply With Quote
Old 05-07-2011, 11:52 PM   #2
Matt Warner
Default Re: Oil pressure
My small block ford has 80 psi cold at idle around 1200 rpm, drops to around 65 to 70 psi warm. I am running a Melling high volume pump and 10/30 oil, what is your bearing clearance? in my experience 80 psi is not uncommon to see with a cold engine and a high volume pump in a small block with .002 bearing clearance. I have heard it said that you want to see 10 psi per 1000 rpm. Mine goes through the traps in the 7000 rpm range with about 85 psi.
Matt Warner is offline   Reply With Quote
Old 05-08-2011, 08:03 AM   #3
Bill Baer
Headsup 113
If you build your motors with ~.002-.0025" bearing clearance like I do my big blocks and use 20-50 oil,80 psi cold is about normal.
I always make sure that I throughly warm the oil before I rev it. Although I have never done it it's probably possible to blow out the oil filter gasket or o-ring if you rev it cold.
Old 05-11-2011, 01:57 PM   #4
67champ
Liked 4 Times in 2 Posts
That does not seems too high with 20/50 cold.....
d
t
67champ is offline   Reply With Quote
Old 05-11-2011, 09:19 PM   #5
Bob Verwold
Bob Verwold's Avatar
Same oil in a 421 sbc and mine has always been 75-80 psi until it warms up.
Bob Verwold is offline   Reply With Quote
