#1 | |
The ahfs was in effect and it was only "supposed" to count national events. Not points meets or records. I got enhanced 8.25% (at one time) And nobody with my combo ever even tripped the trigger for their ahfs. I just hurt the ego's of some of their fair haired boys. A lot of people are saying "they can't". Well in my case they could and did. They won't because they don't want to anger the factories not because they can't.
Art Leong 2095 SS Last edited by art leong; 04-13-2011 at 10:42 AM. |
#2 | |
Liked 136 Times in 49 Posts
How many old combos could you pick up and run 1.7 under first time out with out alot of R and D none. Other than maybe some oddball that slipped thru the cracks. But if the factory racers could only run the index out of the box and need tweeking to go fast people wouldnt be spending $100,000 to buy one. For $100,000 they want runaway in a heads up fast out of the box. |
Liked 20 Times in 12 Posts
1) It is completely possiable to have a weather station at each tech trailer that monotors the weather and factors the given weather back to a standard. Example, STP, standard temp, pressure etc. There could be a correction factor at the end of every qualifying round and that is the number to "correct" the times back to the standard. This would take into account all weathers and elevations.
2) Factor new cars and older ones that have been intruduced into the book fairly. Get a rear wheel HP something, if you have nothing to go by. Look at the entire engine specs. 3) All cars that run fast enough to receive a factor shall be tore down. It does not matter if they pass the scales, fail fuel check or what ever they have to be tore down to be determined legal for the factor. Then if they are found to be illegal then they will be penalized... To me it is real simple.. Hire the personell, give them the equipment and go to it. |
Liked 34 Times in 10 Posts
I guess ole Larry thinks the 396 isn't fair because it carries 45 less cubic inches, two less barrels and 15 more Hp than his car. He believes it needs more because a few people out of the many have been fast. News Flash! Not everyone with one is flyin, and the two times it went under a second this year have been at a factored track and in very unusual weather conditions in Houston. It was like 65 degrees with a huge tail wind. Talk about a self serving agenda hidden under the guidlelines of "fixing" the AHFS.
Liked 3 Times in 1 Post
Do not publish the triggers so that we can manipulate it.
Larry's #1 isn't acrurate. 100lb is not 1/10th on all cars. The more power you make, the less effect it has. Mine, 100 lbs = no more than .08. Higher hp cars is less. Might help, but won't be enough. Probably not .05 with the new Mustangs. Good friend of mine is crew chief on a SBC Comp car, they juggle weight to change classes. He says with their car 100 lbs is five hundredths.
Ed Wright 4156 SS/JA |
Liked 7,891 Times in 1,753 Posts
I agree, seems like 100lbs =.10 works at about J,K,L. Anything higher is less, anything lower is more. In my V car, 100 lbs is .22!
Liked 1,985 Times in 598 Posts
Can anyone tell me what the proceedure is for asking for a HP reduction for a certian combo? Send a letter? Send an e-mail? Who does it get sent to?
Thanks
Mike Pearson 2485 SS |
#9 | |
Liked 24 Times in 14 Posts
Frank Bialas 1570 STK Last edited by Frank Bialas; 04-13-2011 at 12:09 PM. |
#10 | |
Larry decided to call out a combo that in no way needs more Hp, and did it under the guidelines of fixing the ahfs. There are about 150 other combo's out there that need it before this one, but he chose the 396 because it barely went over a second under in two very rare and unfair circumstances by two really, really fast 396's. He did it only because it’s self serving. If he is going to uselessly call out a combo, I'm going to call him on it. Sorry? |
