I just got my comp eng front subframe bushings (solids) It came with 6 bushings. 2 for the rad and 4 for the back. Do I need to order 1 more set to have upper and lowers on the sub frame??
i just used a thick washer and a shorter bolt, looks to be the common practice on most of the cars i see.
do you place the washer on the underside of the subframe (in between subframe and bolt head) and bushing in the middle and nothing up top?
Liked 129 Times in 59 Posts
I believe the bushing is sandwiched between the sub-frame and body - big washer on the bottom.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
I've installed those bushings on 2 different Camaros over the years. First one I did on the cheap, IIRC I used some steel plate to back up the factory washers, last one I built thick washers out of aluminum bar stock on the lathe. IMHO these kits should come with the correct bottom "washers" as well as the bushings. They aren't a complete kit in my view.
Thanks for the reply guys. Im getting ready to install new leaf springs, CE subframe conn, and CE solid bushings, Ive pb blasted the bolts since december, but doing it all in one sha-bang!
