Old 03-28-2011, 08:01 PM   #1
et7333
et7333's Avatar
Default Chevy parts 4 sale
BRAND NEW ‎4 SALE 16 Volt Alternators,ultra minis and std,50-100 AMP $150-$275
BRAND NEW, not rebuilt, mini starter, 3 h.p.,168 tooth - $185.We are having a special if you buy two starters they will be $165 each! These are awesome starters for the price! If you pick up starter at track I will discount the starter $5!
We also now have a new starter for the biggest of big block Chevrolet's it features a true 3 HP motor,a custom made billet mounting plate, and a severe duty sprag drive assembly. This starter is compatible with 139 Tooth flexplates only (ie J&W,CSR,Meziere). This starter has been tested on engines exceeding 800 CI with awesome results. If you have a Big Cubic Inch Engine and 16 volts then this is the starter for you.Email for price
IF YOU DON'T SEE WHAT YOU NEED HERE, I MIGHT BE ABLE TO GET IT. PLEASE, JUST LET ME KNOW WHAT YOU NEED. THANKS
SUMMIT PROTORQUE SBC 1.9 HP STARTER USED $110
8-JE NEW LOW TENSION 4.030X3/16 OIL RINGS ONLY- $25
Manley standard length super duty sbc valves, 8-2.055, 8-1.60 ground and ready to install. - $110
GM 1.60 STAINLESS pro flow ex valves NEW - $65
HELWIG HELPER SPRINGS LP2510 $70
Manley #22441 1.550 valve springs,brand new - $110
MELLING M55HV billet gears oil pump NEW - $40
Moroso oil pump pick up #24360 New - $39
Several powerglide cores, make offer
Factory front drum brakes 68 camaro $60
NEW Comp Stamped Steel 1.5 Ratio 3/8 Stud part#1212-16 - $40
1.76 Hardened powerglide input shaft TURBO splines USED - $55
RJS 5 point Belts outdated - $25
1 USED SET 12 BOLT GM POSI CLUTCHS $40
Manley raised guide plates #42151-8 $12
ARP#134-7101 3/8 screw in studs $20
USED 12 BOLT 4.56 GEARS $75
sbc chevy casting number 462624-These heads are complete,not modified and need rebuild.$125
stock intake #8927184
SBC EDELBROCK TORKER 2,LIKE NEW $70
OLD STYLE TORKER SBC MANIFOLD USED $50
TRANS DAPT CHROME TURBO 400 PAN $25
STOCK HOOD FOR A 69 CAMARO $110
NOTE:
PICTURES AVAILABLE ON PARTS
Prices do not include shipping. PLEASE contact Steve at et7333@netzero.net
WE NOW ACCEPT PAYPAL
http://stevecoxracing.com
et7333 is offline   Reply With Quote
Search this Thread:
Advanced Search
