Old 02-27-2011, 04:31 PM   #1
boss351
Default Re: olds 442 w-30 stocker
thank ,Paul ,so it's impossible to run a stock 455 motor , only with headers and slick with a 442 w-30 ,4 speeds and 3.91 with a spectacuar run at 11.79 ,what do you think about that .
boss351 is offline   Reply With Quote
Old 02-27-2011, 04:39 PM   #2
boss351
hey ,Paul ,, also why olds run in 66 run b/s and olds run f/s in 70
Old 02-27-2011, 05:13 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
just to chime in ,,you would be hard pressed to run that # ,but there is a racer who runs a green 70-71 olds with a 4 speed set up (350 i think ) that could give you some insight on what you need to do with your car i dont have his info but he runs division 1 ,,if i can find the info i will repost gmonde
Old 02-27-2011, 06:10 PM   #4
bigshow2966
Liked 180 Times in 55 Posts
Talking Re: olds 442 w-30 stocker
Isn't Bureski's W-30 in E/SA?
bigshow2966 is offline   Reply With Quote
Old 02-27-2011, 06:10 PM   #5
Mike Brogniez
Would it be S Murray.............
MB
Name:	Numidia Jul 23-24 012.JPG
Old 02-27-2011, 06:23 PM   #6
Paul Ceasrine
Liked 10 Times in 10 Posts
Boss351,
The weight break factors changed over the years.
Oldsmobile 4-4-2
as per year
1965,,,,,,B/S
1966,,,,,,C/S
1967,,,,,,B/S
1968,,,,,,D/S
1969,,,,,E/S
1970,,,,,F/S
It fell into the 9.50-9.99 wt/hp from 1968 and up.
In 1965, 1966, 1967 the class wt/hp was 9.50 - 10.59
Super/Stock
1967,,,SS/E
1968,,,SS/F
Old 02-27-2011, 06:33 PM   #7
boss351
wow ,this is all informations that i need ,thanks again Paul and also for the others guys .
Old 02-27-2011, 07:24 PM   #8
gmonde
gmonde's Avatar
MB
yep that is the one j/s he also has a 66 or 67 442 stocker 400 maroon
