Old 02-24-2011, 07:57 PM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Air loss in slicks
There are a lot of variables between tires - compounds, construction techniques, etc.
When I bracket raced, I also "painted" the insides of the Phoenix tires I used back then with dishwashing soap because of varying air loss. Started with the Hoosier radials also in Stock but found out they didn't need it after I started getting them mounted at the races.
My 3-piece Holeshot wheels are silicone sealed from the manufacturer. But also check the metal valve stem seals and shraeder (spelling?) valves periodically.
Old 02-24-2011, 08:13 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Air loss in slicks
I run every brand of slick over the past 2 decades and Phoenix are the worst for leakage, on the rims in 2 days with M/T coming in second.
I never soap my sidewalls, don't have to cause I run Hoosier slicks
Hoosiers don't leak air!
Old 02-24-2011, 08:49 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
I have very little loss in my Hoosiers but dismount/mount can be hard on the sealant in 2 piece wheels that have aged some. Just spray some soapy water on the wheel itself to check for that.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-25-2011, 02:02 AM   #4
Philip Saran
Liked 14 Times in 11 Posts
Tomorrow or Saturday I will pull the wheels/slicks off the car (on
jack stands now) and dunk them in a large bucket of water.
The wheels are a used set of Weld 15/8 and they have holes in
the rims for screws, but I do not have screws in them.
Thanks for the input.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
