Liked 2 Times in 1 Post
Did you install the codec pack?:
http://www.cccp-project.net/download.php?type=cccp If that doesn't work you will probably have to use VLC player. Should be easy to find on google. Sometimes there is something installed that prevents the player from using the correct codec. VLC player has the codecs built in I think. I've tried VLC player before I didn't like it because it associates all audio and video files to it. You can always uninstall it later though. If you are using windows media player, you should be able to right click on the video and select properties and it should tell you which codec it is using. It should say ffdshow video decoder or H264. I'll go ask the pit workers what time the gates will be open for competitors. I'm guessing 7:30, but I'll go check to make sure. -Toby Last edited by Toby Lang; 02-23-2011 at 05:10 PM. |
Much better. Thanks.
Jeff Interlicchia 7077 D/SA 1998 Pontiac Firebird LT1 J707 E/T 1966 Dodge Coronet 500 |
I talked to Harold and Gary and they think the gates don't open until 8 AM, but they're not totally sure. They also think you'll have to come in through gate 15. Will be kind of hard to get pitted and teched in time to make the first qualifier if they don't open the gates until 8.
They said they would check and find out for sure. I will go ask them later. -Toby |
The drag is that they close at like 5 or 6pm tonight because of noise curfew, or I would just come after work. At the finals I can't remember what time they let us in on Thursday, but it was pressed to get teched in time. Please let me know what you find out, or if they will be open late tonight. Thanks.
Jeff,
I talked to them again and this time they radioed up to somebody that knows what's going on. According to the guy on the radio, you come in the same gate you normally would (Gate 17) and line up there. They are supposed to park you at 7 AM. Sounds a lot better than what they were saying before. ![]() -Toby |
With an 8:15 start time tomorrow and weather threats/early noise curfews I would hope they would give us more than 15 minutes to get in and get warmed up! We aren't sure what time we can start engines, if anyone knows and can pass it along....like Toby with gate times, no one here seems to give the same answer twice. We heard 8 a.m. but not sure.
![]() I will try to help Toby in his reporting and take some pictures tomorrow as well. We are thrilled to be here, but a bit nervous about the forecast. Today's wind is a serious factor protector. There must be a steady 20+ mph head wind today, sure glad we aren't racing elims into that! |
No race motors are allowed to be started before 8 AM. They said there are supposed to be parking racers at 7 AM. Most people just tow their cars to tech so they don't have to start them. Somebody should have a rental car you can borrow for towing.
Edit: I reread your post and take it that you are already here and teched. That's the way it's been for years. Start motors 8 and run Stock at 8:15 -Toby Last edited by Toby Lang; 02-23-2011 at 06:55 PM. |
#8 | |
#9 | |
Liked 14 Times in 11 Posts
Toby,
Thank you for your reporting/pictures/videos it makes not being able to attend a little better.
Phil Saran Parker, Colorado |
