Old 02-16-2011, 01:41 AM   #1
cujo3116
cujo3116's Avatar
Default Re: When do you activate your Throttle Stop?
We have two Stop cars, a H/R car that runs 9.90's and 137 and slowed to 10.90 and a S/R car that runs 9.00's at 149 and slowed to 9.90.
With the hot rod car I come on the stop at .050, my static rpm is 4000RPM and its on the stop usually around 2.2 seconds, shift on rpm at 6600. Its a grunt motor and runs 10.90 at 136 MPH. My 60's are typically 1.70 with the stop on and 1.39 all out.
The Super rod car I have tried setting up 3 different ways so far in testing.
Tried going on stop at .200 at 5000 RPM and shifting at 7000 RPM (on stop for 2.5 seconds. 60's were all over the place
Tried goin on stop at .100 and shifting at .800 on time (stop rpm of 5000 again) on stop for 1.8 seconds average) consistant 60's but car seemed to struggle coming off the stop in high gear
This past season set it up to go on stop at .100 at 4300 rpm shift at 7000 rpm and was on stop for 2.1 seconds. this way seemed the best for consistancy, my 60's were very consistant and the car was soft coming off stop and charged well. Still struggled abit with ratio it seems but overall this set up worked best.3
As many have said theres a 1000 ways to do it, but sometimes its nice to see what others are doing and maybe get a fresh idea or something new to experiment with to see if you ride likes it or not.
Andrew
cujo3116 is offline   Reply With Quote
Old 02-16-2011, 08:31 AM   #2
THE LEGEND
My car runs 9.90
In 10.90 I stopat .20 come off around 2.20-2.30 depending on air. I shift around 3.25
10.90 around 132
A lot depends on your combo. What works for others may not work for you
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 02-16-2011, 10:03 AM   #3
Rollins_2241
I want to clear the beams before on the stop (.270) because data on delay and rollout is vital and don't want to make my bracket data useless.
With a 4150-style carb and an old box I can only come off in low gear. I try to kill it down to 4200, and am usually on for 1.5 to 2.2 seconds depending on the air. When it comes off I shift on RPM, to me using time is another variable to avoid unless you need it (high-power car). I usually run 131-134 all out and only lose 1 mph on the stop.
Rollins_2241 is offline   Reply With Quote
Old 02-16-2011, 03:37 PM   #4
65Shoebox
65Shoebox's Avatar
Some great feedback guys. Thanks and keep it coming!
We are planning to test one or two different approaches tomorow at G-villle.
I think that we have been stoping and shifting too early based on the feedack here. Also, I like the approach of letting the car work on the line and then getting on the stop once it settles. This may be .5 out for me, but we shall see...
65Shoebox is offline   Reply With Quote
Old 02-16-2011, 10:25 PM   #5
HR9121
HR9121's Avatar
Originally Posted by THE LEGEND View Post
My car runs 9.90
10.90 around 132
Chip Johnson
Hey Chip, just curious about shifting on time after you come off the stop, I just assumed that might make you shift at different rpms depending on how long you were on the stop. Have been curious about that but have never tried it. Just wanted to hear your thoughts about that. James Williamson (Legend in my own mind)
Old 02-22-2011, 06:25 PM   #6
65Shoebox
65Shoebox's Avatar
BTW. This feedack helped tremendously. The car is 60 footing with great consistency, and the ratios are working. I am now going on the stop at .3 and shifting about 1/2 way though the time on.
Thanks all!
Old 02-22-2011, 08:49 PM   #7
EricArrow
EricArrow's Avatar
Thanks all!
Good to hear...
Low and Slow
EricArrow is offline   Reply With Quote
