Liked 13 Times in 7 Posts
What is considered extreme valve spring pressure in a stocker?
N/A |
Liked 138 Times in 51 Posts
Some of the composite lifter engines have moderate roller-type pressures. They even recommend starting at 170-180 closed on the seat.
add a hundred
Chad Rhodes 2113 I/SA |
Liked 154 Times in 37 Posts
Hi Terry------You're dead on. Worst rule change ever. Started all this BS.
66W30POST |
Banned
Liked 235 Times in 110 Posts
Hi bud......Its good to hear from you. Its a nice 77 degrees here in sunny Fla. today....lol. I see your listed as being in Florida ? Question is....how can the stock racers every get this stuff changed back to some sort of sanity?
Hi Terry---I'm still working in Va. with a connection to Jensen Beach for the past 15 years. Wish I was down there with you full time but still have family obligations. I'm afraid class racing will never get back to what we grew up with and love. Too much work for the new sanctioning bodies run by bean counters and not people like you and Farmer. Majority of the class racers are eligable for Social Security and still racing the cars they bought new. As Macarthur said, like the old soldier, "They'l just fade away". As for me I'm putting my ( bought new ) Black 66W30 2dr post together for D/S . So find yourself something to race ( 4 speed of course ) and Craig and I will come to an association race down ther and try to wear your ***** out. Then fry up some burgers and dogs and drink alot of beer.
66W30POST |
#7 | |
Banned
Terry Last edited by X-TECH MAN; 01-19-2011 at 10:45 PM. |
Banned
Any pressure that requires a "Shubeck" style modified lifter that cost more than roller lifters thats used in S/S ! Like Danny (Hi Dan) said in the post below......150 lbs seat pressures 350 open MAX should be all you need. Saves wear and tear, less breakage from lower RPM's like a stock engine was designed for. Then you could run the OEM stuff until rebuild time. Some of these "Stockers" are being turned up to "Never Never land" on the shift points and in the traps. No wonder the racing associations had to allow aftermarket rods (more expense). Stock was never meant to be S/S. Max valve spring pressures in this range would be one rule change I would vote for instead of allowing S/S type replacement parts every time someone breaks an engine because of turning a stocker to 8200 + RPM with a stock capacity oil pan. This is also one reason some have used "Cheater" heads and intake manifolds over the years to allow for more air flow. Its the Associations fault for letting the rules get out of hand.....not the racers. They just use what the associations allow but it cost EVERYONE more and more to stay competitive. My 2 1/2 cents and Im sticking to it !
