Liked 100 Times in 45 Posts
Since we're a bunch of malcontents and bitchers and moaners here's a question.
What ONE rule or procedure would you like to see our fearless leaders in Glendora strictly apply in this coming year? One and one only. Fasten your seat belts,it's going to be a wild ride.
Former NHRA #1945 Former IHRA #1945 T/SA Last edited by Ed Fernandez; 01-14-2011 at 11:08 PM. |
Liked 17 Times in 7 Posts
"The Golden rule" Treat others as you would like to be treated. If you apply that everything will be just fine!
Banned
Liked 235 Times in 110 Posts
Apply the correct HP factors to any and all combinations no matter what the year they were built. New, old, injected, carburated.....dosent matter.....by getting rid of the AHFS for starters. .
Mandatory retirement age.
Don |
Liked 112 Times in 31 Posts
Ed, Are you saying that you know of cars that have set records that HAVEN'T been torn down? If so, where? And better yet, who?
We've been torn down five times at National Events over the years and in several instances have still had the seals on the engine a couple of weeks later and set the record, and we always have to tear down again for the record. Jerry |
Liked 320 Times in 102 Posts
Maybe it says in the East Coast NHRA Rule Book if you hold your mouth just right you can skip the Record Run Inspection.
The West Coast NHRA Rule Book "requires" an inspection after setting a record. There you go, see the East Coast Rule Book is better than the West Coast Rule Book. We haven't set any records on the East Coast, so we always had to pull it apart after setting a record
Dump the accepted fuel list................$10, $12, $14 a gallon for some pretty colored, NHRA sponsor stuff is obscene. Pump gas only. Everyone bring 5 gallons to tech, dump it in a big tank, stir it up and take 5 gallons back. Now we are all on the same page at a reasonable expense.
#8 | |
I figured this thread would go to ***** (not your post Jerry),and it didn't take long.NHRA is going to get away with letting our eliminators go to crap due to lack of pressure on them to correct a lot of problems,whether caused by us or them. I think I'll pull the plug on it. NHRA does teardown cars when a car runs fast enough to set a record.The incedent I saw concerned a car going stupid fast,then coming back the next run without the B on the window.That's not NHRAs fault.That's a case of the racers making a mockery of the system.It was his option to do that,but it doesn't mean it's right.The other incedint was the alledged radiator emptying a while back. I hope that clears up my statement,which I have deleted from my original post.
Former NHRA #1945 Former IHRA #1945 T/SA Last edited by Ed Fernandez; 01-14-2011 at 11:07 PM. |
Liked 774 Times in 164 Posts
Ed,
I never saw anyone set a record and not come apart. What did I miss?
Dave Casey 1330 STK |
Ed,
I get where you're coming from. Thanks! Jerry |
