Liked 180 Times in 55 Posts
That is one slick little Rambler.
Liked 1,104 Times in 302 Posts
I am no AMC expert, but I believe the 69 SC/Rambler that were equipped with that scoop were functional, using a vacuum operated flapper door similar to the 1969 Torino/Cyclone and 69/70 Cougars. Is that correct? Also, I believe that the 390 SC/Ramblers were also all 4 speeds, is that also correct? Since this Rambler American 2 door sedan is shown at a NHRA santioned track, in M/SA, how is he allowed to run that scoop, functional or not? Wouldn`t that be like a 68-69 Barracuda with a 340, 383, or 440 Stocker using a SS/AH Hemi hood scoop? Or a cowl induction hood on a 67-68 Z/28, or Boss 429 scoop on a 428 CJ Mustang? Just curious.
Liked 3,181 Times in 972 Posts
Jeff Lee will address I'm sure but think your correct on the SC. Think the non-functional scoop is a discretionary thing on the part of NHRA tech since it clearly offers no performance advantage. Is it technically incorrect, sure; but it would be chicken-***** to bust him on it just like it was to bust Art for his non-functional louver fenders on his Neon.
Thanks Jeff for the info & link
It's Very Nice... and worth your time to check it out here... http://www.autobarnclassiccars.com/v....aspx?Item=298
Larry Fulton |
#5 | |
Liked 100 Times in 45 Posts
The SC/Ramblers were all 2 dr non post cars,390,4speed in A and B paint schemes.All had functional ram air setups.They built 1512 of them.They cost $2,995.Road test times were 14.30 with grandma driving.They really would go 13.90s.
Former NHRA #1945 Former IHRA #1945 T/SA |
It didn't hurt the fact that the car weighed less than 3000#.Still impressive.You can't touch a nice one (not a clone) for less than $40K.
#8 | |
The issue of this M/SA Rambler scoop was brought up before on this forum. My comment was something like "if legal for show only, I'd make sure I had the rust spots under the scoop!" Apparently NHRA doesn't care. At one time the rulebook said "mild customizing allowable". I guess this factory scoop could fall under that. And technically speaking, and an easy fix, the air pan under the SS/H SC/Rambler is a no-no also. But lets just get the car on the track! If the owner needs to see an application I'm @ 602-418-9797 ! ![]()
Jeff Lee 7494 D/S '70 AMX |
Liked 165 Times in 59 Posts
If the owner needs to see an application I'm @ 602-418-9797 ! jeff i dont know about the no-no ,,,check out some of the super stock 440 6 pack cars that have sheet metal intakes with an aluminum pan's that are not factory pieces but like jeff says get it on the track cool piece non the less gmonde |
Supposed to have stock OEM air filter canister or tub if using a factory ram air system, even in superstock.
