View Poll Results: Opinions on consolidating classes | |||
Combine Sticks and Automatics |
33 | 14.73% |
Spread Weight Breaks (i.e., .5 for upper classes, .75 for some, then to 1.00 lb breaks) |
22 | 9.82% |
Both of the above |
36 | 16.07% |
LEAVE IT ALONE! |
133 | 59.38% |
Voters: 224. You may not vote on this poll |
Thread Tools | Display Modes |
#11 | ||||
Liked 13 Times in 9 Posts
2) I would agree there's been *too* many changes, many of which have generated unintended problems themselves. 3) How would having less classes (presumably ending up with more heads up runs) make it more like bracket racing? It's exactly the opposite. Quote:
![]() ![]() The topic gets brought up for time to time in various forms. I just don't remember seeing a poll covering it. It is the silly season, after all. We need something else to b*tch about. ![]()
#12 |
Liked 132 Times in 30 Posts
What I can't stand are those who bicker over "soft indexes" or "too many classes" after they've hit their performance plateau. Or they bitch that they need "better valve springs" or "allow roller rockers" blah blah blah. The rest of us in the meantime are just trying to get around the performance curve with what we've got within the exisiting rules and class structure. For those who feel things are "too soft" or need more relaxed rules my advice is go buy a couple "For Sale" signs and move on to another more expensive project like a S/S or Comp car, and leave Stock alone. Just my $.02
Gary Smith "another broke racer spectating" |
#13 |
Liked 66 Times in 23 Posts
lol
#14 |
'Cause Michael has one. Just ribbing him a little.
Ed Wright 4156 SS/JA |
#15 |
If FWD cars were to be absorbed into RWD classes, you wouldn't be able to do it stricltly on a weight break basis, for the following reason.
-AF/S, 13.00-15.99 pound weight break. 13.85 Index, 12.95 Nat'l Record. 13 pounds is K/SA, with an Index of 12.65 -BF/S 16.00-17.49 pound weight break. 14.65 Index, 13.67 run at Indy 16 pounds is P/SA, with an Index of 13.45 -CF/S 17.49-18.99 pound weight break. 15.15 Index, 14.17 Nat'l Record 17.49 pounds falls into Q/SA, with an Index of 13.80 -DF/S 19.00-24.99 pound weight break. Index 15.60. 14.66 at Indy 2009 19 pounds is T/SA, with an Index of 14.40 -EF/S 25.00-more pound weight break. 17.45 Index, best runs in the 16.30's W/S is the lowest class, 24 pound weight break, 16.65 Index With the exception of EF/S, not one FWD record is even close to the corresponding RWD weight class Index. IF there were consolidated, I would be in favor of adding FWD cars into RWD classes with similar Indexes. So DF/S would be added into V/SA instead of T, and so on with the other classes. Adjusting weight breaks for all classes (either .75 or 1 pound classes) would be easiest. Not sure how some classes would work where the stick and auto are rated differently, then NHRA would have to get into weight breaks for the autos (or sticks, in some classes), and would be a bih hassle. IF 1 pound classes were made, I'd think a rule of one class only should be written, so a car wouldn't have to try and adjust 800 pounds or more, in the upper classes, to make the currrently-legal three class rule. Natural B/SA (8.50) can run A (8.00) and C (9.00). If the new classes were, say: A/S - 7.00 B/S - 8.00 C/S - 9.00 etc etc Then a car could only run it's natural class, and eliminate the need for removing/adding rediculous amounts of weight to change classes. Same with Super Stock as well. Just my opinions. Personally, I'd prefer it be left alone for a while, and if I HAD to vote, I would go with the altered (3/4 to 1 pound) weight breaks.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#16 |
Banned
Liked 235 Times in 110 Posts
Stick and automatics should be rated the same. Its the same friggin' engine.
#17 |
I agree.
#18 |
Liked 1,912 Times in 429 Posts
I disagree. Some engines simply work much better with a stick than they do an automatic. Some engines work well either way. Considering the wide variation of bore/stroke ratios, rod/stroke ratios, carburetor sizes, and cylinder head CSA's, just to name a few factors, to say that all engines work equally well with sticks and automatics is simply a generalization that cannot be true, nor can it be supported.
Alan Roehrich 212A G/S |
#19 |
Mike, In order to put the FWD's in the other RWD classes properly they would need to drop the HP ratings appropriately. That way the weight breaks would be correct. All the FWD cars would move down some classes to the appropriate indexes.
BF/S 1985 Grand Am 3.0 V6 |
#20 |
Owen, that would probably work. My shipping weight is 3,444, and the NHRA and factory rating is 170, so I'm a natural U/SA (20 pounds), with a 14.85 Index. I'd only need 13 hp taken off (down to 157), to make V at 22 pounds.
Hope all is well up in NY.
