#11 |
The few trailers that I have towed in the past, I have crossed them but did not know why I did it. Now that I have my own trailer, it is nice to find out how to actually do things the right way.
A question about hooks. Do you run the hook into the hitch hole from the top or up from the bottom? So the open would be facing the truck or trailer? My hooks have wire like springs that cover the open surface of the hook, so I don't think they would bounce out, but nice to know if there is a correct way.
Rick |
#12 |
When we bought our last trailer, I made the comment to the dealer that the chains looked a little small. The trailer is 36' long and 13'6" tall so it is pretty heavy. He told me that if the hitch breaks the last thing you want is to be attached to the trailer. The small chains will break so the trailer doesn't take you in the ditch with it. It made sense to me so we left the smaller chains on it. I guess that is what insurance is for. LOL
Ryan Koener S/G 310C |
#13 |
I guess you aways learn something new, I had never heard of this !!!
Does crossing the chains apply to a goose type hitch as well ?? |
#14 | |
Not only is their advice insane, it's illegal.
Chris Williams 6304 SC, TD, ET |
#15 |
No. The truck bed will support the tongue as you slow down, and the chains will keep it on the bed.
#16 | |
Pat I. |
#17 |
Not trying to change the subject , but aren't the small battery's hooked into the break system there for just that reason. When the cable breaks it automatically puts on the breaks.
Stopping the carnage that your out of control trailer might cause....... |
#18 |
I wonder how many people with bigger enclosed trailers have safety chains that meet the defined "each safety chain having an ultimate strength at least equal to the gross weight of the towed vehicles"? Take a look at chain ratings here: http://www.1st-chainsupply.com/WLLchart.htm
It looks like anyone with a bigger trailer needs two 5/8" chains to be legal! On edit (I'll blame it on the cold medicine): Looks like ultimate strength is 4x WLL for Grade 70 chain, so 5/16" Grade 70 should suffice (I have 3/8" Gr 70 on mine now). My trailer (16k GTWR) came with 1/4" chain held on with cold-shut links. Trying to pull the trailer over a hump in my driveway, the coupler broke loose. Fortunately the trailer didn't roll as it was hung up on the driveway, but the cold-shut links broke so easily I didn't even feel it in the truck. I discovered at that point that my breakaway switch was corroded and had quit working as well. From now on I check the breakaway switch monthly during racing season.
Michael Pliska 643 S/G Last edited by Michael Pliska; 11-12-2010 at 11:31 AM. Reason: Correction |
#19 | |
Or... you could drag the trailer, still hooked up to your tow vehicle and its brake controller, over to the side of the road, and stop it under some modicum of control. Seems like a pretty clear choice.
#20 |
There are sad, and preventable, consequences to trailers being towed improperly, or illegally. A good friend and co-worker with my wife was on her way home from her shift as a nurse. It was a dark, wet, winter night and the highway was a mix of two lane changing to four lane sections. A small utility trailer (the type that have no lights and do not need to be registered) heavily loaded with firewood and being towed using an 1&7/8ths two-piece ball broke loose and crossed into the path of the nurse's car, killing her instantly.
Not long after that, an insurance investigator came by the dealership where I worked and asked if we sold that type of ball. Wasn't long before those were outlawed. Don't skimp on this stuff. |
