Old 11-11-2010, 10:25 AM   #13
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
Default Re: What Do You Think About This?
Originally Posted by Toby Lang View Post
Using the wrong carb is nothing new. People have been kicked out for it many times before. I think most people do it to move up the qualifying sheet then put the legal carb back on for eliminations.
As far as I know the penalty for getting caught with the wrong carb is only a DQ from that race. There is no suspension. Someone correct me if I'm wrong.
Bolting on a bigger carb is probably the easiest way to cheat. I think it should deserve more than a one race suspension.
-Toby
I think this happens WAY more often than people think. I would like to see hoods opened for some sort of inspection after time runs at divisional events. Check a carb, pull a valve cover, check for aluminum driveshafts, etc. I'd bet you would see quite a few cars slow down. As this thread points out, it usually the cars at the bottom of the ladder that cheat more than the guys at the top!
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is offline   Reply With Quote
