#31 |
I got caught with a aluminum drive shaft during tech in..It was simply a mistake I was running a lot of IHRA which its legal lollll..They let me run the national event after a brief discussion..To this day I feel the aluminum drive shaft is safer!!!!
#32 |
Liked 317 Times in 103 Posts
I was at a race, opps, i mean that I knew of a friend that went to a race and was found to have the wrong carb 4bbl instead of a 2bbl. The tech guy was real upset about the whole thing. So I, I mean this guy then told the tech guy about a system that is employed in intergalatical travel evasion, and before you know it the tech guy just looked a little bit wierd, looked me, him right in the eyes and said in a very low tone "everything seems to be in order sir, have a good day" So my friend went back to the pits, qualified with the 4bbl, and ran eliminations with the 2bbl. And no it was not a Jedi mind trick, though somewhat similar.
Ron Ortiz U/SA open your mind
Ron Ortiz 2102 STK |
#33 |
Liked 460 Times in 91 Posts
1976 Summer Nationals Class Win..................... .001 light on deck after that was asked to leave..........
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#34 |
Liked 902 Times in 192 Posts
Bob - Was that with the Vega???
Bob Don 128 SS |
#35 |
#36 |
Liked 100 Times in 45 Posts
Serves you right for running a Vega.:>):>):>)
Former NHRA #1945 Former IHRA #1945 T/SA |
#37 |
Be nice Ed, I even raced a AMX one time in 69..............
#38 |
That makes everything better,Bobby.
#39 |
No more HONEST people..................
#40 |
This is for all you guy's that long for the good old days in stock. In1976 I won class at the Summernationals. Had a 1969 Mustang CJ with a stick that ran D/S. That's back when stock meant stock! Went thru tear down with no problem till they asked me what kind of hyd. lifter was in the car. I said TRW and they informed me that they had to be FORD! The rule book said OEM and I took that as OEM replacement. I was wrong and they were nice, but sent me on my way!!!!!!! The stick car back then would bend valves every week the car went out. See you had to run stock valve train back then. Springs were checked both open and seat. We were allowed 97lbs on the seat and 298 open. Used to have to buy 50 springs at a time to get 16 good ones. I still have over a 100 springs left and I have been doing engines in my shop for the last 40 years. In 1977 we changed to a automatic and set the record. We felt pretty good about ourselves so my partner went to the 1977 Sportsnational's in Bowling Green, KY. He won class and during tear down the guy helping him knocked the two valve springs and shims they were going to check off the table before they had checked them for pressure. They gave them one chance to put the shims with the right springs. Bottom line, one spring was 12lbs lite, the other was 2lbs over!!!!!!!! So you guys that want to go back to the good old days can have them. I for one enjoy what the class has evolved into!!!!!!!!!!!
