Liked 2 Times in 2 Posts
So let me get this straight. Ti valves are not legal for Stock replacements?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Even though I would be against Ti valves, one thing to consider is the cost of custom valves. I can buy SS valves off the shelf for my 390 AMC and they are competitively priced against all the other makes. But my engine builder takes valves for other makes and then does a lot of work to them on the back side. Flow improvements are significant. So I can't imagine my guy is the only one doing this. I would guess there are some big name builders and probably more of those "best kept secret" builders who do the same. I don't know what the final cost is (I just know how much the big ticket is
![]() ![]() Of course if they were Ti, the modifications may be just as high, if not higher due to the extra machining process. On billet cranks...my guess is they will allow them. Why do I say this? Because I just spent stupid money on my factory forged unit. And every time I do this, a new rule comes out that would have been cheaper and easier! ![]()
Jeff Lee 7494 D/S '70 AMX |
Liked 520 Times in 132 Posts
If we keep going like this why don't we just say run whatever you want and NHRA can just check cubic inches. I'll say it again Comp here we come. I predict after this gets thru aluminum heads are next.
The argument will be..."since we have to change all the seats to match these valves and these heads are so old...blah, blah, blah"
If I were to build say a BBC, I would call Comp Cams. I believe they would tell me I need a 55mm camshaft in this engine because it would flex less than the standard camshaft because of the spring pressure I will be using. Then I would send the block to a machine shop to have the lifter bores machined to accept a Chrysler lifter because the std GM diameter lifters don't seem to have the life of the larger bores. A set of .165 pushrods are recommended for strength also. I would call T&D or Jesel for a rockershaft system because the old Crane rockers and a stud girdle just won't last. . Now I have all these special parts and machine work to prevent flex in my valvetrain but am not allow to use a slightly lighter valve of the same dimensions in those highly modified heads. That makes sense.
I have a friend who runs a 69 Chevelle with a 500ci motor and a stick. 3300lbs. He has run a Jerico transmission, and for many years run a paddle clutch with 2500lb pp. He has never broke a transmission in almost 15 years. How? He replaces the transmission EVERY year. If Barton never broke a valve it may be because he replaces them at every rebuild-which is what 25 runs in those cars? I'm the guy who refuses to put a clutchless transmission in his car because I feel it's takes away from what a SS car should be. But I'll put titanium valves in my engine in a heartbeat. Any guys that feel different, put a 8000 chip in your 2-step and push the gas petal to the floor and hold it there. Thats what a stick car does on the starting line. I vote YES. ________________________________ Andy Stone 1102 A/S 1112 SS/C Last edited by Stick Racing; 09-17-2010 at 04:23 PM. |
#6 | |
Liked 20 Times in 14 Posts
8000 rpm???????? |
Since BBC are not my realm, I consulted with somebody that really knows these things. Regarding a Super Stock BBC, he told me the aluminum BBC heads (401?) could outflow the capabilities of the 2.19 valves; i.e., the valve is the restriction, not the ports. So adding a Ti valve, while not being larger, would certainly add 500 or so RPM. And that is where the benefit is. The "cork" can now cycle many more times down the track. He thought the 396/375 would really like this option.
We also discussed my 2.02" intake 390. His opinion was the valve was probably light enough and the heads don't flow enough; in other words the flow numbers of the head are more closely correlated than in comparison to the BBC. So that gives some insight as to who or what can benefit the most from such a change
Go to the track and watch Jimmy Bridges make a run then report back to me.
______________________________________ Andy Stone 1102 A/S 1112 SS/C Last edited by Stick Racing; 09-19-2010 at 03:01 AM. |
Liked 161 Times in 52 Posts
alum heads are legal for some combo's.
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Stephen I know that you get my point. Ed
