Old 09-10-2010, 10:00 PM   #11
lstanford
Liked 134 Times in 32 Posts
Default Re: Super CJ
Originally Posted by BlueOval Ralph View Post
The question of the day is does the SS/AA have the correct cage?????????
If your that worried about the cage, why don't you check it out personally. You seem to be an expert on everything else.
lstanford is offline   Reply With Quote
Old 09-10-2010, 10:08 PM   #12
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Originally Posted by Bruce Noland View Post
Jason Fuller's post was removed because it was obscene. Enough said!
Thank you Bruce.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 09-11-2010, 04:47 AM   #13
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
My thanks also......
Mack Reeves
2377 STOCK & SUPER STOCK
Old 09-11-2010, 08:50 AM   #14
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Cool Re: Super CJ
So that little engine is making like 900 plus horsepower.
astikhossw is offline   Reply With Quote
Old 09-11-2010, 09:48 AM   #15
Superfan1
Superfan1's Avatar
Liked 2,637 Times in 440 Posts
Smile Re: Super CJ
It is probably closer to a 1000HP. The classification guide lists the coupe at 500HP with a shipping weight of 3220 lbs which gives it a factor of 6.44 making it a natural SS/A or SS/AA car (6.00 - 6.49). In order to run at the class minimum, 220 lbs would have to be removed from the car. Assuming that it was possible to do so, Hopkins would be at the same weight (3000 lbs) as the SS/AH cars. His ETs and speeds are pretty much equal to what a Westcott or Barton powered SS/AH will run, and I am pretty sure that they are right around 1000HP.
Bill Seabrooks - superfan1
Bridgeport, CT
Old 09-11-2010, 11:46 AM   #16
Jared Jordan
Liked 536 Times in 119 Posts
Send a message via AIM to Jared Jordan
The CJ in SS/AA trim has to weigh the same as a 4-speed SS/AH (3170) and is 40 lbs lighter than the automatic SS/AH (3210). In SS/BA the CJ weighs 3420, or the same as the Hemi B-Bodies.
The scary thing is that we still don't know how fast those cars can really be. Yeah, we've all got a pretty good idea, but what happens when one of those cars is back-halved and they can really lean on them in the first 100 feet of the racetrack? I have no idea what the 1st gear ratio is in those C2 transmissions, but all those cars look pretty lazy leaving the starting line in comparison to, say, Armstrong's Vette or Percy's Savoy.
One more thing: you think they've got the throttle blade all the way open? I don't...
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 09-11-2010, 11:46 AM   #17
BlueOval Ralph
Banned
Will Jamie and Jesse issue a recal and update the 2010 or the 2008?
Originally Posted by T Ketels View Post
With nearly a 20 mph headwind as well - just wait until tomorrow morning to really see what it will run. From what I remember, it looked like an 8.50 cage and not a 25.5.
Tim
BlueOval Ralph is offline   Reply With Quote
Old 09-11-2010, 12:01 PM   #18
BlueOval Ralph
Banned
Don't you mean got the throttle blade's all the way open?
Old 09-11-2010, 02:12 PM   #19
Superfan1
Superfan1's Avatar
Smile Re: Super CJ
I didn't add in the 170 lbs. for the driver (3170), so our math is basically the same. I have heard that they run the throttle blades only 56% open. Wow!!
Bridgeport, CT
Old 09-11-2010, 05:03 PM   #20
Tom Meyer
Liked 354 Times in 120 Posts
Randy is tearing down for the record at earlville right now and not running first round. Tom
Tom Meyer 5240 SS Stock ???
