Old 08-17-2010, 12:01 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Default Re: 2 Unrelated questions but need some help
Go to building supply store and look for silver colored silicon in a caulking tube that says it is for sealing aluminum windows. Be sure the area you want to seal is very clean - use laquer thinner, brake parts cleaner, etc.; the surfaces should be sqeaky clean. Apply the silicon sparingly and forced into the gap between the wheel halves. Too much silicon will add to the mass of the material and can be forced out by the inertial forces of the wheel spinning at high rpm.
That's the procedure I have always found to work.
This is what I did and looks to be sealed good so as soon as I get the tires mounted we shall see. Thanks!
'65 Mustang SS/L & L/SA
