#11 |
Liked 797 Times in 165 Posts
Yes, the s10 only comes that way I think, and my race cars are disc/drum also.
Dave
Dave Casey 1330 STK |
#12 |
Liked 2 Times in 2 Posts
Ok, we have changed direction and will be going 4 wheel disc.... Would this M/C still work?
Recomendations on bore diameter if I bought an aftermarket?
Tod Lane Swartz & Lane 66 Nova Swartz & Lane 79 H/CM Trans Am |
#13 | |
Liked 7 Times in 5 Posts
There is a new Ford master cylinder on eBay that is aluminum with a steel cap. The eBay item number is 270360589638. Rawhide |
#14 |
Liked 15 Times in 11 Posts
Lyn: Stainless Steel Brake Coporation (ssbrakes.com) has an aluminum master cylinder the looks like the cast iron Corvette version (their part number 0476) one inch bore for manual disc brakes and only weights four pounds. You can order them from Summit or Jeg's also!
#15 |
#16 |
Liked 20 Times in 7 Posts
Anyone know where I can get a new brake rod that goes into the back of the master cylinder. I have a 24 MM bore size dodge aluminum master cyclinder. Thanks.
#17 |
i just went through all this. a late 70's early 80's pickup is 1 1/8 bore, mid 80's diplomat is 1 1/16, and mid 80's daytona is 24 mm which is under an inch. BUT i put one on my car and dont like it and am gonna go to the diplomat. also most of the new mastercylinders are cast iron replacements but the rebuilds which are like 15 bucks are aluminum. hope it helps.
#18 |
Liked 91 Times in 51 Posts
This has the info for the Mopar M/Cs:
http://www.dragstuff.com/techarticle...sterCylPN.html |
#19 | |
