#1 | |
As for another motive, sure I'd love to get my head lower in the vette, it's a tight squeeze. But the weight would be no advantage as we already run weight on the nose and have to run a second battery and 40lbs of lead to make even AA/SA. What's your reason for being so against race seats in a stocker???? Got a fortune tied up in a pair of Swiss cheesed lightened stock seats?
Chad Rhodes 2113 I/SA |
Liked 115 Times in 5 Posts
Since the HANS prevents overextending the neck and head in an impact where your body goes forward (in most cases), why does the headrest in the seat matter?
As for seats, the stock seat in my Mustang, a vehicle built in the 1990s, has slop in it and I would be safer in a properly designed racing seat. Most of the non-racing aftermarket replacement seats are not held to the same factory crash standards and would likely be no safer than a stock seat, even an old one. In fact they could be worse, despite being seemingly sturdy. Most stock seats have lots of bracing in the back area, in order to hold up in a crash, or severe back injury will result. I have actually spoken with Ford vehicle engineers about this in the past. There are, however, lots of good aftermarket drag racing and road racing seats on the market. A solution could be to run a factory seat from a later-model vehicle. Then you don't have to worry (as much) about a weight issue. Surely, a seat from a 2010 Camaro, Mustang or Dodge will be plenty safe. I started wearing gloves when the pants rule was put in place. I felt that I should apply logic because ironically, you don't need fire protection on what to me is the two most important areas of your body—your face and hands. In the case of a fire, I want to protect my face (I wear a full face with shield down) and my hands. Most of us need our hands to make a living, so why wear a jacket, pants, helmet, and no gloves? I just made it part of my routine and it's no big deal. It took me about 10 runs to get comfortable with them. I also have an on-board fire system. I agree with Greg in that perhaps we should look at seats because many cars are old and have potentially worn-out seats, tracks, hardware, etc., but those seriously interested in safety should also follow Dave's advise and first get everything allowed to protect yourself. Evan
Evan Smith 1798 STK Last edited by Evan Smith; 07-18-2010 at 05:06 AM. |
Evan, my understanding on the Hans issue is that due to the soft nature of a factory headrest, combined with the amount of padding in a stock type seat, could allow the Hans to come out from under the belts in a violent crash. No matter how tight you think you have strapped yourself to a stock seat, there is stil some give in a seat made mostly of foam, as opposed to aluminum. That's just what I was told when I started asking some questions
Liked 1,436 Times in 299 Posts
I understand the challenge between stock appearing and safety. I think there would be a way to do it. Now maybe the spec could have caveats such as which class, or mph or cage spec, those would be something.
I have run our car in C stick to K stick. I added a full cage. I know aftermarket seats would be lighter too. I think that some sort of agreement would have to be arranged as Greg Hill stated. I don't agree with 5 hp, but I do think there should be something that makes the safety issue make sense. For example, I could see some stockers that have old bolt in 3 point bars dropping in an alum kirkey and keeping the crappy old bolt in bar. It would not be logical and it would be clear that safety was not primary. I go back to the disc brake issue. That topic was beat to death for safety, but it was really about saving weight. I remember one racer that had a late madel Camaro or Firebird crying about safety for his daughter, and yet the car came with factory 4 wheel discs. He had taken them off and put drums on. He could have legally put factory 4 wheel discs on and not had any issues stopping. He chose not to because they were heavy. Don't get me wrong, I put the disc brakes on my car too when they were legalized, but we could have gotten by without them. I think the seat deal is worth discussing, but we should look for solutions that satisfy stock looking and safety. The liklihood that a stocker will crash is pretty low, but the seat failing is high if you do. I think that is a good enough reason to discuss it. You could make the same case for helmets, firesuits, rollbars, etc. We don't have to fight about it, but coming up with real solutions based upon everyones experience is good. I don't think the money for a seat is an impact item here. I spent more getting mine recovered than I would have spent on aftermarket seats.
James Schaechter 3163 STK |
Liked 328 Times in 80 Posts
Hi Greg and others on your stock seats. I know for a fact you can tie up 1200 bucks in 2 Jaz aluminum seats (not as tall as Kirkey). That is if you want to make your stocker look stock. You know the custom matching upholstery. I made all the mounting brackets/hardware for mine, lightweight of course. It took about 6 hours and had them plated with yellow Zink. The $1200 doesn’t include the plating or material for the mounts. Oh, don’t forget you must support the backs of both seats to the crossbar of the rollbar. They may be safer, not sure, but they are definitely lighter. The Kirkey and Jaz seats have some covers, but don’t match most interiors. M. J. Quinn did my seat covers to match my door panels. I had the opportunity to set in Jeff Nicewanger's Jaz seat before doing mine, much better than the Kirkey. Kirkey is what we put in Glenn Betz Sunfire.
Ernie SS3400 |
Dave,
I thought I could get away with it, but you figured it out. My car will easily pick up a tenth with set of Kirkey's. Bastardization of stock, WOW, I like that. I hope next year they do more in one year then then did in the past five years. Funny, the young guy (Dave) wants Stock to be more like Stock, and the old guy (Ken) wants Stock to progress (sorry I ment to say basterdize). What the hell is this sport coming to? All kidding aside, this not a big issue for me, Its just something I would like to see happen. Racing is dangerous, it does matter how much safety equipment we have, we still can get hurt. I am not a purist when it comes to stock. Stock became a bastardization when they let us use the first none stock part. I guess it comes down to what each racer considers stock to be. Everyone has there on opinion on where the line should be drawn. For me the line is irrelevant. |
#7 | |
Liked 98 Times in 23 Posts
Ken, we also know you aren't a purist, that's why you race a car with options that it never came with, and you are building a car that was never offered on the street! ![]() With all of the "enhancements" we have had shoved down our throats the last few years, to me, the seats will be the biggest aesthetic change to hit stock eliminator. Today you can look inside a stocker and still resembles what it did when the car was original. The seats go a long way in making this resemblance. This is the point I and it seems a few others on the post are driving at. A Jaz or Kirkey seat does not belong in a stocker.
Dave Ficacci 1013 STK 1170 SS |
#8 | |
#9 | |
Also, you are a big man to call people names behind a cute name like clutch man. Sign your real name and we'll talk. I've probably forgotten more about what it takes to swing the stick then you will ever know.
Dave Ficacci 1013 STK 1170 SS Last edited by Dave Ficacci; 07-18-2010 at 01:41 PM. |
Do the mustangs and challengers have racing seats?
