Old 07-17-2010, 09:15 AM   #1
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Default Re: Elgin now making Stocke Eliminator rockers
Originally Posted by Greg Reimer 7376 View Post
I just got through building a stocker motor a few weeks ago and used Elgin 7/16" SBC rockers. The studs were some conventional 7/16" screw in studs, the rocker arm part number is Elgin R-1840, and the rocker arm ball is Elgin RM-1000. They must be purchased separately.The poly locks are conventional BBC 7/16" items.Hope this helps!!
R-1840N will get you the rocker and ball together.
Description of Nitro Rocker Arms R-1840N
Nitro rockers 1.50 ratio with heat treated 7/16 grooved rocker balls. Nitro Carb Rocker Arms are back!!!!! * Look Just Like Stock Parts Precision die stamped to deliver the most accurate ratiosof any stamped steel rocker * Greater Resistance Wear 3-5 times the strength than stock. Eliminate pushrod cup and fulcrum faliures. * Nitros are Dyno-Proven and Cycle tested and Race track proven.... * Long Slot Design * Ideal for Extreme Valve Spring Pressures * Strength of Ceramics at Fraction of the Price * 7/16 nitrited balls included *
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 07-17-2010, 01:01 PM   #2
Greg Reimer 7376
Liked 705 Times in 219 Posts
Thanks for the updated part number. I bought all these parts about two or three years ago, probably a lot else has changed as well.R-1840N it is!!
