Old 06-26-2010, 07:02 PM   #1
Liked 1,830 Times in 415 Posts
Default Re: Fender clearance?
Before you move the axle, you better check your wheelbase. There are specs and limits on wheelbase, and they do measure it.
Old 06-27-2010, 11:37 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
I saw some rubbing with 1.25" clearance for Hoosier 30x9 bias, 116 mph, 8" wheels. I hear the tires don't grow as much with 10" wheels.
Old 06-28-2010, 10:44 AM   #3
cad
cad's Avatar
Liked 91 Times in 51 Posts
We're researching the same to determine if we can run a 30x9.
Steve at Hoosier tire:
The radial does not grow. It is easier to spin if the track is not good.
The Bias tire will grow about 3" in circumference, or about 1" in diameter, on the 8" or 10" wheel at 120MPH. You will get more runs from the bias tire.
They recommend the same burn out for both tires. The 10" wheel will give a slightly flatter footprint meaning a little more rubber on the ground, not a big difference.
cad is online now   Reply With Quote
Old 06-28-2010, 11:45 AM   #4
Ed Wright
Ed Wright's Avatar
Cad, that info agrees exactly with my experience.
Ed Wright 4156 SS/JA
Old 07-11-2010, 09:13 AM   #5
tom51
68 camaro..trimmed quarter panel in front for more clearance. you may need to cut the rear too. i also made steel wedge plates and moved my rear back about 1/4 inch or less..no more rubbing now. or you can make a few runs and watch the smoke fly at the end of the track. tires get smaller with each rub..
tom51 is offline   Reply With Quote
Old 07-16-2010, 06:17 AM   #6
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Not a nova, but on my chevelle i have about a 1/4" of clearance on the front side. i run the 92" roll out 30X9 radials. I can also run 27 pounds of air in them if the track is there, to a .92 under. I currently run 22 pounds of pressure for testing during regular bracket racing days at my track. These are on a 8" rim, running 5.13 gears and 2.75 first gear. I wish they made them in a 30 x 7 radial, i'd probabley mph like crazy! (i/cm).
Ian Hill is offline   Reply With Quote
