#1 | |
Liked 174 Times in 39 Posts
Liked 136 Times in 49 Posts
As far as the rule on rocker ratio. I think what the HRA’S need to do is measure the valve lift at the rocker. Measure the lift at the cam. Do the math if the ratio is correct or under they are legal. If it is over they are out. No matter what it says on the rocker.
Liked 4 Times in 3 Posts
I have a question?
What if the rockers are under spec? We all know that there isn't a factory rocker arm that comes close to spec out of the box so what if your 1.6 ratio factory rockers come up 1.54 or 1.5 rockers are 1.46 etc? Should you be bounced then also?
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
#4 | |
Liked 1,937 Times in 582 Posts
Mike Pearson 2485 SS |
Liked 327 Times in 121 Posts
Banned
Liked 235 Times in 110 Posts
Last time I looked the rule was + .001/ - .005. This rule came about due to the 426 Hemis having a problem with the valves clipping each other in S/S with the high lift cams. Dave Wren was bounced at Gainesville when I worked for NHRA in 1974 because of this. His valves were several thou undesized for clearance.
#7 | |
#8 | |
Banned
#9 | |
Liked 1,836 Times in 417 Posts
Alan Roehrich 212A G/S |
#10 | |
Banned
