Old 06-15-2010, 02:28 AM   #1
rayfin
Default Re: Another Racer Killed at E-Town
I was wondering why the chute just fell off of the one car and the roll cage was completely "broken" off the other car?
rayfin is offline   Reply With Quote
Old 06-15-2010, 08:48 AM   #2
Liked 1,814 Times in 413 Posts
I do not know why the chutes came off of the car last year, nor why the brakes failed.
I'm pretty sure they cut the cage off of the top of Neil Parker's car. That is standard operating procedure for removing an injured person from a wrecked race car. It's actually SOP for removing injured persons from most any wrecked car. The first concern for emergency personnel is to get the injured person out without causing further injury. If you take them out the top, you can do a better job of keeping the spine aligned. If you have to turn them and lay them over, odds are if there is a spinal injury, you'll make it worse.
It is interesting to note that the car that crashed last year lost its chutes, and reportedly lost its brakes, yet it went through both nets, but the second net was still holding the car somewhat, and the tire barrier stopped it. In the crash this year, the car evidently, from the photos, went through the tire barrier, and was a good distance past the tire barrier. It would appear that this year's crash was at a much higher speed.
Old 06-15-2010, 09:00 AM   #3
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
I believe, in the Alexis Dejoria accident in 2009, when the 'chutes ripped off, they tore the brake lines too.
Old 06-15-2010, 09:14 AM   #4
That would explain that wreck. I thought I read somewhere that oil or something fouled her brakes, but you may have information from a better source, or something they found later.
Old 06-15-2010, 11:05 AM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: Another Racer Killed at E-Town
Alan.....50 cubic inches isnt enough. Cut all of the fuel, and alcohol cars back to 400 inches. Back in the stone age they used 392 and 426 Hemis in nTop FOOL. . Why not now. Cut the blower size and over drive, fuel pumps and mags. They wont do it though. Slower in in the spectator eyes as the way to go.
Old 06-15-2010, 11:27 AM   #6
Terry, if you cut the blower speed way back, they only have to buy pulleys, not blowers. If you cut blower size, then you have to keep cutting speed.
If you cut compression, 50 cubic inches will be enough. If you don't cut compression, 100 cubic inches won't be enough.
If you make the changes easier and less expensive, it gives the teams a greater incentive to not just accept the changes, but to embrace them.
If you let them keep the same blower size, they don't need entirely new blowers, that keeps the cost down. It's a lot cheaper and easier to control it with pulleys. The most it requires then is belts and pulleys, as opposed to entirely new blower cases and manifolds.
If you take 50 cubic inches and compression ratio away, you can just change pistons and crankshafts, those are expendable anyway. Just take a 1/2" of stroke, and cut the compression ratio. Considering how much nitro loves stroke and compression, that will kill a lot of power.
They'd be better off not to cut mags, it'll help keep them lit, they hydraulic and explode when they're not lit. When you take displacement, compression, and blower speed, they'll slow down the fuel pumps themselves.
Old 06-15-2010, 11:37 AM   #7
k.pascoe
If I remember correctly the last two T/F records set in 1/4 mile were at two of the shortest tracks (Columbus & Pomona) and it was done safely. Just make sure the damn chutes work. It's easy people, if the chutes don't work it doesn't matter HP or lenghth of the track.
k.pascoe is offline   Reply With Quote
Old 06-15-2010, 09:12 AM   #8
It probably is time, and a good idea, for NHRA to look at taking some power away from the fuel cars, as they've far exceeded the design parameters of the tracks, and some of the parts they're using. Some of the older, more experienced crew chiefs have been saying that quietly for years.
If they simply took 50 cubic inches away, limited compression, and restricted blower speed, they could take 1000HP or more easily. For the cost of new pistons, new cranks, and new blower pulleys. The result would be the ability to return to 1/4 mile racing, less expense for the teams, and less time and money wasted on oil downs and fires.
The use of tailhook arrester gear on race cars probably isn't too practical. An entire new structure would be required for the back of the cars, requiring a whole new level of engineering. And it should be noted that these cars are not designed to be pulled or stretched, it might be necessary to redesign the whole frame to withstand the forces acting on them from stopping them abruptly by hooking the back of the car. Otherwise, it rips the back of the car off, and then catapults it further down track. Pulling cars apart is not a good idea. Further, even the best carrier pilots jump the wire, so there's no sure way to make sure the cars catch the wire, if the car doesn't catch the wire, the system is useless.
Perhaps a better idea is to use the braking technology from arrester gear on an improved catch net. The cars are designed to protect the driver from a front end crash, so the net shouldn't require massive changes to the cars. A stronger net, designed to actually capture the car, coupled to a braking system might do the trick. It's not going to tear the cars up any worse than the current system, either.
A longer sand/gravel pit, starting sooner, might be another improvement. Starting the pit earlier, and making the entrance less aggressive, might help stop the cars from skipping over it, as well as giving them more time to slow down gradually. It would also stop the slower cars less abruptly, with less damage and less chance of serious injury. It would allow an extra net or two as well. If we had two regular nets, possibly somewhat stronger, and better mounted, that would slow the cars more gradually, and stop some cars completely. Then, with a third net, with arrester gear style braking, as a final fail safe, you have a system for the fastest runaway cars.
