Old 06-14-2010, 10:29 AM   #1
Billy Nees
Liked 7,723 Times in 1,738 Posts
Default Re: Drooze & Teuton
Owen, the cam grinder will make you whatever you want.
Billy Nees 1188 STK, SS
Old 06-14-2010, 11:40 AM   #2
James Perrone
Liked 1,821 Times in 425 Posts
Question Re: Drooze & Teuton
Where is Drools
Former world champ driver?
Never had one?
Or did it Kaboom again?
james perrone 1290 STK
Old 06-14-2010, 12:32 PM   #3
Owen S Quirion
Billy, My point was why would a camgrinder grind a cam that hits the lift number with 1.65 rockers unless that's what he wanted to do. If the guy making the cam thought that the rocker ratio was 1.6 and you install it in an engine with 1.65 rockers, the cam would check over the high spec. Right?
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
Old 06-14-2010, 02:13 PM   #4
Jeff Teuton
Liked 325 Times in 50 Posts
There is always some variables in valve gear. Pushrod deflection and length, valve spring pressure (checking spring vs running spring), lifter puck height just to name a few. Anyway it was my mistake so we will fix it. I don't anticipate much change on a small cam like we use in stock eliminator. It ain't like them 1" lift things in Super Stock. If the ratio wasn't stamped on the rocker, nobody would care. Very few have anything stamped on them. And like almost all rockers, the things don't check 1.65, but closer to 1.60. The 1.60 checked closer to 1.56 hence the 1.65. Anyway it's done. We still had a good time.
Jeff Teuton 4022 STK
Old 06-14-2010, 04:00 PM   #5
art leong
Back in our hemi days we would grind the rocker tips, and play with pushrod length. To get the cam to check legal.
Like Jeff said I doubt there would have been anything said about it if the ratios weren't stamped into the rocker.
I wonder if those people complianing here would like their ratios checked
I think some (a lot) of people would be upset.
Art Leong 2095 SS
Old 06-17-2010, 12:04 PM   #6
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Originally Posted by James Perrone View Post
Where is Drools
Never had one?
Nope....no kaboom.
Nothing other than getting ready and finishing my house.
Just havent had a computer around, they dont react well to drywall dust and wood chips.
We got a driver.....a 2 time world Champ
Came out of "retirment" to race for us ..... actually Hiatus is more like it.
Stand up guy......
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 06-17-2010, 01:15 PM   #7
Ed Wright
Ed Wright's Avatar
Why the games about who it is??
Ed Wright 4156 SS/JA
Old 06-17-2010, 01:27 PM   #8
Andrew Hill
Andrew Hill's Avatar
Liked 170 Times in 38 Posts
Originally Posted by Chris "drooze" Wertman View Post
Nope....no kaboom.
Stand up guy......
Keith Lynch?
Andrew Hill is offline   Reply With Quote
Old 06-17-2010, 01:34 PM   #9
novassdude
Liked 136 Times in 49 Posts
As far as the rule on rocker ratio. I think what the HRA’S need to do is measure the valve lift at the rocker. Measure the lift at the cam. Do the math if the ratio is correct or under they are legal. If it is over they are out. No matter what it says on the rocker.
novassdude is offline   Reply With Quote
Old 06-17-2010, 01:54 PM   #10
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
I have a question?
What if the rockers are under spec?
We all know that there isn't a factory rocker arm that comes close to spec out of the box so what if your 1.6 ratio factory rockers come up 1.54 or 1.5 rockers are 1.46 etc?
Should you be bounced then also?
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
