I plan to go at the SuperNationals 06/10/2010 .This is the first time .Is there camping that accept motorhome? or is there hotel close to the track?
any help should be appreciate .Thank |
Liked 9 Times in 3 Posts
i believe there is camping allowed at the track . it is outside the track . if you have been there recently, it is right by the road coming in before you get to the track by the mx practice track. i don't know if you need reservations or not. i would call the track and check for sure.
Mark Markow 171 ss/tb |
Liked 2,637 Times in 440 Posts
There are quite a few motels on Rt. 18 which leads to the track. The problem is that usually there is a lot of traffic on Rt. 18 especially on Sat. and Sun. The motel that I use every year is the Red Roof Inn in Monmouth Junction, NJ. It is 16 miles from the track and it takes about 25 minutes to drive it on backroads with no traffic to speak of. Make your reservations on the Red Roof Inn website and use Mapquest to print your directions to and from the track. Good luck.
Bill Seabrooks - superfan1 Bridgeport, CT |
#4 | |
I have book at Red Roof Inn ,Thank for the info,Are you going at the Supernational?
yes i will be at the race.
There is also a Days Inn Rt. 9 Freehold which is about 10 to 15 minutes to track.
Stocker, I will be there before the gates open on Thurs. June 10; also you have a Private Message.
