Old 05-30-2010, 09:26 AM   #1
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: SuperNationals Englistown
i believe there is camping allowed at the track . it is outside the track . if you have been there recently, it is right by the road coming in before you get to the track by the mx practice track. i don't know if you need reservations or not. i would call the track and check for sure.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 05-30-2010, 11:14 AM   #2
Superfan1
Superfan1's Avatar
Liked 2,637 Times in 440 Posts
Talking Re: SuperNationals Englistown
There are quite a few motels on Rt. 18 which leads to the track. The problem is that usually there is a lot of traffic on Rt. 18 especially on Sat. and Sun. The motel that I use every year is the Red Roof Inn in Monmouth Junction, NJ. It is 16 miles from the track and it takes about 25 minutes to drive it on backroads with no traffic to speak of. Make your reservations on the Red Roof Inn website and use Mapquest to print your directions to and from the track. Good luck.
Bill Seabrooks - superfan1
Bridgeport, CT
Old 06-01-2010, 08:28 AM   #3
Stocker
I have book at Red Roof Inn ,Thank for the info,Are you going at the Supernational?
Stocker is offline   Reply With Quote
Old 06-01-2010, 08:35 AM   #4
Mark Markow
yes i will be at the race.
Mark Markow
171 ss/tb
Old 06-01-2010, 08:45 AM   #5
Tracey Harrington
There is also a Days Inn Rt. 9 Freehold which is about 10 to 15 minutes to track.
Tracey Harrington is offline   Reply With Quote
Old 06-01-2010, 10:24 AM   #6
Superfan1
Superfan1's Avatar
Stocker, I will be there before the gates open on Thurs. June 10; also you have a Private Message.
Bridgeport, CT
Old 06-01-2010, 08:26 AM   #7
Stocker
thank Mark for the info,Are you going at Supernational?
