Old 05-21-2010, 06:54 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: choosing a car for stock eliminator
1) Build a car you really care about. It doesn't have to be your favorite car or anything, but you do have to be willing to attach your identity to it.
2) A lower class car is not necessarily cheaper than a faster car. Example: a '66 chevy II with a 283 is not any cheaper than the same car with a 327. Engine combinations that have been beat on for years will be more expensive than less exploited combinations, because the standard for engine performance has been raised to a level that will require expensive technology.
3) A manual trans entry might be cheaper in some instances and the expectation performance level lower. Sam Murray's Olds. is a great example.
My nickel's worth of opinion, and probably more than you want.
