Thinking about it more I would agree with what Bob and Mark both said. With the 60 foot you had the trans and drive shaft did not see a huge amount of torque. And I assume from what you said it did not shake or shudder on launch. It didn’t happen until the trans was in drive and starting to get up in RPM.
So probably something driveshaft related. The one thing I would check on the remnants of your transmission is the tail shaft bushing to make sure the yoke was not super sloppy in it. Could your drive shaft have been bent or dented? or overall length or yoke length a little short? Or touching drive shaft loop? When Jim works on it you may want to also consider a roller bearing in the tail shaft. Is that Peter Legg’s old car? Are you going to have it back together for Bosie?
Bill Edgeworth 6471 STK |
Dave,
I had several case failures with my TH-200, fortunately caught before catastrophe struck. I tried to buy a brace from McClay, but he only supports his own transmission customers, or at least did at that time. I built my own brace connecting the two "eyes" on the passenger side of the trans with 1/2" thick by about 1" wide aluminum. I tried to upload a photo but the file is too big. Email me at grant4060@yahoo.com if you'd like a few photos. I also bought an aluminum deep pan from Turbo-Action to act as a girdle and give more strength to the case. I run this behind a big block stocker, 3570 lbs. with best of 1.41 60' and since the changes have had no further troubles. The transmission is a reverse pattern unit built by Jim Mantle, who is the greatest guy to deal with, and his units have always performed perfectly. Ditto on using the stock rear mount, also would suggest the left front torque strap from earlier posts. Make sure there is enough spline depth in your driveshaft yolk so that it cannot bottom out when the car launches and the rear end pushes it ahead. Hope this helps, Grant |
