Liked 13 Times in 7 Posts
When any of you fail your fuel check after a run are you then draining the fuel and refilling it with new fuel and then flushing the entire system for a few seconds?
Or are you pulling your tank and scrubbing it clean and will the fuel check staff verify your new fuel before using it? Someone mentioned scrubbing their tank in a post awhile back, but what does that exactly mean?
N/A |
Liked 325 Times in 50 Posts
They have always helped us any time. We got a bad 5 gal. in Gainesville, had to take the foam out of both cars, dry it, clean the tank and give it a few minutes to evaporate. They tested our new fuel, and then tested it again out of the car before we ran again. Great help. Also told us what was probably wrong. Somebody probably used that jug for some pump gas and didn't dry it out after.
Jeff Teuton 4022 STK |
We've had C12 from a new jug right off the VP trailer fail. More than once. We picked up some ET and consistency going from C11 to C12, and stuff stays cleaner. But it fails fuel check regularly, or comes really close. We're deciding what to switch to. And we buy ours direct from a VP distributor, by the drum. It is sealed, the fuel system in the car gets sealed, the jugs are carefully maintained and sealed, and stored in the dark. We've done everything they've asked, and still it either fails, or we get warned we're close.
We can usually pass fuel check after a problem by simply pumping it all out and flushing it. I don't remember having to do anything major. We tossed the foam years ago. It holds dirt, and it comes apart. We keep the cell topped off instead, it keeps the weight more consistent.
Alan Roehrich 212A G/S |
Fortunately I don't have foam installed and keep the fuel in the blue VP cans and not in jugs, so I hope that helps but who knows. The C11 in the tank has been sitting all winter, so I doubt it will pass. Jeff you mentioned cleaning the tank, so do you just wipe it out and re-fuel it.
I was assuming I would just drain it and fill it with a new can and flush the system for 3-5 seconds.
N/A |
[QUOTE=Alan Roehrich;179606]We've had C12 from a new jug right off the VP trailer fail. More than once. We picked up some ET and consistency going from C11 to C12, and stuff stays cleaner. But it fails fuel check regularly, or comes really close. We're deciding what to switch to. And we buy ours direct from a VP distributor, by the drum. It is sealed, the fuel system in the car gets sealed, the jugs are carefully maintained and sealed, and stored in the dark. We've done everything they've asked, and still it either fails, or we get warned we're close.
I'll be glad to sell drums to any racer who wants it -- just call .And at a reasonable price .........
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#6 | ||
If we were stupid or careless with our fuel, I wouldn't complain. But we do everything VP says we should, and we still have problems. I like the fuel itself, other than it makes the plugs look funky. But when it constantly fails a fuel check or it is borderline, there's a problem, and VP just will not address it. We've been lucky, we've never been DQ'd. But then, NHRA has been somewhat accommodating, too. We're simply not going to keep taking chances until we waste a weekend and $1500 on a DQ.
Liked 60 Times in 12 Posts
Manny, I have no real answer why, but twice, I have checked C 11, that was bought late the previous season, and it passed both times. I keep mine in the dark blue jugs almost always. I have an O ring in the top of the cap on one. I did buy some 12, 4 yrs ago, and it failed right out of the can ! Carried it right back, swapped it for 11 and no more since then.
I did buy some 11 last yr that caused all kinds of problems though.... It killed a pump, and regulator, and gunked up the carb,and ate the inside of the lines, so after swapping out the whole deal, it has been fine since.
2894 STK |
Liked 6 Times in 2 Posts
Quote. We tossed the foam years ago. It holds dirt, and it comes apart. We keep the cell topped off instead, it keeps the weight more consistent.[/QUOTE]
Just wondering, but doesn't removing the foam negate the safety aspect of a fuel cell?
Dale Posnick |
#9 | |
What most of us run really isn't a fuel cell, it's a plastic fuel tank. A real fuel cell is a can with a bladder in it.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 04-03-2010 at 01:42 PM. |
