Old 03-03-2010, 11:46 AM   #1
FED 387
Liked 334 Times in 181 Posts
Default Re: How much of your current ride, did you build?
2 things I learned over the years can be summed up by these 2 sayings that I heard many years ago
"any asshole with a checkbook can buy a racecar it's what he does with it that counts"
AND
"you don't know anything about your race car until you know everything about your race car"
I keep remembering that over & over again---Helps me ---I enjoy putzing around fabricating and coming up with better ways of doing things- On my dragster I built everything except the frame/chassis and the cylinder head otherwise my partner, my wife and I did it all --Comp387
Old 03-03-2010, 01:38 PM   #2
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
I couldnt agree more....even the things I didnt do have been through (except trans)
Bikes are very very much the same except more dangerous, and Im not puttin my *** on anything I havent had my hand in everything.
With the exception of 1 accident every one was a mechanical failure. Of those 1/2 were known issues I decided to run anyway, none were anyones fault but mine, I like the fact I can never have any one to blame but me Makes life easy...I dont have to carry around animosity
Chris "drooze" Wertman is offline   Reply With Quote
Old 03-03-2010, 02:50 PM   #3
chris3racing
I build everything on our car. Been doing it for a long time no reason to change now. The roll cage was installed by someone else only because he had time and equipment. He did a good job. Since I have been in the structural engineering busness for 40 years, I know the frame is welded and braced properly. Every piece of the car I look at either every week or every two weeks. Not only do I drive the car but my son drives it. Don't believe he would be doing that unless I have looked at everything.
chris3racing is offline   Reply With Quote
Old 03-03-2010, 03:08 PM   #4
Liked 5,147 Times in 1,964 Posts
Let's see , The engine , carb, converter, trans ,rear end , sub frame connectors,suspension and alignment, wiring, body work , and paint.
Of course , the machine work was done by Rick Watters Ent / Tibor Kadar,
but I had to buy my own torque plate for a 2300, which they now have in their possession.
Same deal on the Omega before this one, including the headers, too.
I like being in control of the situation, as you can tell , but the main reason is , this is the only way I could afford to play in this arena.
Old 03-03-2010, 04:01 PM   #5
danny waters sr
danny waters sr's Avatar
Thumbs up Re: How much of your current ride, did you build?
Started from scratch 3 years ago on a 66 nova 4-door 283 stocker. My son and i did everything but roll bar, engine & ,trans. this was a parts car a guy had and was keeping for the front clip. Was way cheaper than a two door and is diff and gets a lot of looks. I took before pics and after pics. As i said 3 years and still working while running it. It will be my last one that i build ,the next one will be already done ( if there is a next one ).
