Old 06-08-2007, 09:41 PM   #15
classof65
Default
Alan and all. My problem NOW isn't the miss we were chasing. NOW WE CAN'T GET IT TO START AND STAY RUNNING.... I've checked the box and it is good doing the MSD suggested test, I've removed the tach and all the other "stuff" hooked to it. I've put a new pick up in the dietributor - Thanks Alex D - I've tested the wires. I've looked at the cap and rotor and they appear fine - I've "cleaned up" thw wiring. We've tried TWO coils.
What started as an attempt to fix a strange anomolie has turned into a dark oddesy. At least it ran before.
Any suggestions now that the obvious has been covered>
Could it be my ignition switch?
Peace, Rev.
Alan, you are absolutely correct USUALLY a pick up is either good or bad, but when your car won't start you try anything. I might even try standing on my head.
classof65 is offline   Reply With Quote
