Old 02-15-2010, 12:06 PM   #4
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: Push rod limitations
Ian, the marks you're seeing are normal with that diameter pushrod. no need for 3/8, if you are uncomfortable, get some .116 wall 5/16 to reduce the flex. a small amount weight added on this side of the rocker is not as big a deal. do not enlarge the opening unless you're going to use guide plates.
Wade
