Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 02-05-2010, 07:04 AM   #1
bill dedman
Liked 6 Times in 4 Posts
Default Re: Slant-6 solid roller lifter cams?
Thanks! I'll give them a try.
Bill
bill dedman is offline   Reply With Quote
Old 02-08-2010, 03:46 PM   #2
bill dedman
Well, it turns out that for at least two good reasons, nobody runs rollers in slant 6's:
1. They don't turn the 225's any rpm (6 grand, mostly) and they don't need high valve spring pressures for that, and you don't need rollers with reasonable valve spring pressures.
2. The valvetrain is light enough to warrant the use of weak valve springs (given the rpm) so nobody wipes cams....
3. And, because of that, nobody makes blanks for roller cams for these engines.
Case Closed!!!
Bill
