Old 02-04-2010, 07:12 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Stock Tech Questions
Originally Posted by foxy343 View Post
Wondering about NHRA Stock rules for framerails, can they protrude through the floor boards? They do right now stick up approximately one inch through the floor.
Also if there is a roll bar installed already do I still need a back seat? Can the seat be cut to accomodate the roll bar? Can the battery be relocated to the trunk?
About the trunk, it is pinned with hood pins right now, do I need to install the stock trunk hinges? I think a fuel cell in the trunk is legal now, any suggestions or recommendations?
Frame rails thru floor ,OK.........no back seat ,OK ,with steel or aluminum firewall.........Battery in trunk ,ok as long as the origional battery is retained in the front. ...Both batteries are supposed to be the same also,but I rarely see that enforced.........Hinges must be replaced ,hood pins OK with original latch installed....................Fuel cell ,OK................Tom
