Old 01-30-2010, 04:46 PM   #1
BlueOval Ralph
Banned
Default Re: 09 Challenger/Mustang engines
In as much as the Bosch system, if youve ever priced their "BASIC" system for a road course car it STARTS at about 20k, but many sanctioning bodies REQUIRE its use...the price of something like that from Bosch is meaningless it lends nothing to the ability of the system. If I find my BOSCH racing pricelist Ill send it to you, first time I read it I thought the europeans added a bunch of 0's after everything.......it got filed in the "I aint paying for that" file promtly years ago.
The Bosch for DI in ALMS as used is not the same as the as the Bosch 4.0 as used in the Rolex Series 4.0 is a spec ecu, as is the engine wiring harness. As for ti handling the phaser if it is a Enna phacer it needs a Enna drive controller and wiring harness.
Originally Posted by drooze View Post
Nope not talking about the 8, talking about the 6, the 3.6 and several guys who helped with the protoype work on those systems will make custom sticks to any spec. (they made our stick to even though it isnt VVT of course) and they also make the other type as well. I opted for what I call the "NUCLEAR Option" enough ramp to be just short of breaking lifters, I assume 50 passes from a set to stay safe at first, well see maybe 100....but no more, I can still sell em for 1/2 of what Ive got in em with full disclosure of what was done with them to the "tuner" and street scene guys afterward so its not as expensive as it sounds, same with springs.
The 6 is a DOHC 4vpc engine that can BREATHE as well.
In as much as the ECU is concerned there are currently 3 systems on the approved list already that can handle the 4 cam phase, 2 for sure have generic code to do it that require some leg work, 1 for sure have the ablity and have already done it althought its not an "advertised" feature of their system and is in their firmware as "experimentaL"
Im not going to say which one and whose......YET....because its one were running and they are our Main Sponsor..Itll be a little Obvious at Pomona......I know the system and I also know several people running it with VVT, and a couple with DI, noone both yet but the system is not only capable but already approved.
The FIRMWARE code revision is meaningless as well for NHRA specs, and if you have access as I do to the "proprietary code" and a capable programmer , I myself am (Im talking raw code C and assembler) not the "code" the "tuners" think theyre doing. I opted to pay a small consultancy fee ($500)to a programmer overseas in England who has infinite familiartiy with this sytem, he had working in 2 days what John Meany resorted to a modified cam wheel and external crank trigger on the 6.1 for. It would have taken me a month in front of a scope writing the code, I wanted to eventually but well....$500 was a better way to go. That code is now available to all people running the system, so I paid to move up something on their "to do" list. AS Long as the Hardware is off the shelf available its Kosher......simple....
I dont know if Meany ever had the code finished for the other system, well get to see if Coughlin is running an external crank trigger. He was our choice at first but well after I saw what I considered to be a "hack" to get it running running at the time only 1 plug, I said crap I can do whatever I want.......I called up Bruce Bachelder to find out the system I really wanted to run would take to get approved, only to find out it had just been submitted and approved a month before but not by the manufactuer.......so its kosher.
The shop Im standing in now (typing this on the dyno console...lol) has 1 DI engine and 1 VVT phased twin cam motor within sight, both foreign but like I said before Drag is new to them, they hold some land speed recrods and mostly RR stuff but...........They custom harnessed my whole car from 12 to 10pm last night ... all computers in all tails run......I about fainted when I came in this morning, the elves had been busy.
The last part of the statment is incorrect , the NHRA has already approved several systems that are capable and in production and available over the shelf.
BlueOval Ralph is offline   Reply With Quote
Old 01-30-2010, 05:20 PM   #2
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
No Im sure its not , its also 25 k more.....but what Im saying is with Bosch price is meaningless, they are expesive period like for a simple Rolex system which isnt rocket science, and CERTAINLY not worth 20k.
The point, my point, maybe I wasnt clear and its my fault.
In 1 to 2 years the DI VVT 6 will be capable of outrunning nearly every small displacment 8 out there. IF people develop the engine potential properly.
That was the point, the Camaro 6 has YEARS of potential, its all R&D, when they throw HP at it, so what there are 32 other things to find it on with a system like that ONLY concentrating on the Cam and Fuel alone.
Phasing the cams can be done already with the ECU were using, so that becomes moot, the DI can be done, like I said BOTH at the same time havent but thats because noone has tried, not that its not capable.
Mark my words the 3.6 Camaro will make a killer Stock Eliminator car, with years of potential, UNLESS the NHRA sets phasing specs, they havent so far, but it COULD happen.
This is a whole new animal to them.....to a large extent, how the rules are changed to reflect it will be interesting.
And the other point was GM has dropped the ball with as much potential as the Camaros DO have, and Im a Dodge Guy, I wouldnt mind putting my hands on a Camaro 3.6......
What you seem to be saying, and please correct me if Im wrong, is contrary to what Im saying, hence you are saying the Camaro 3.6 has no great potential, and that you think DI and VVT phasing isnt really going to gain much. (aside from the fact I can run 12:1 on 86 octane with a DI system)
Like I said, I think it has the potential......you seem to think its too hard and not doable ? Well......like Eisntein said "Wether you think you can or not, youre right"
So I guess were both right
Chris "drooze" Wertman is offline   Reply With Quote
Old 01-30-2010, 10:17 PM   #3
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Hey Chris,
the SCJ Mustangs run in SS only.....they are not stock legal.....although they offer the 08
combo for 2010 and it can run in stock.....
One of the Mustang guys....Rock
CBS is offline   Reply With Quote
Old 01-30-2010, 11:20 PM   #4
Ok......now Im stumped.....I know what you know is correct so maybe you can help enlighten me. I havent paid near as much attention I should have but I should have but Ive been too busy trying to make this combo best (and I dont want to get too jealous of the 4 liter super
Correct me if Im wrong.
The FR500CJ (the 2008) can run ONLY AA correct (now) could run A and AA when it came out)?
Apparently in calling them SCJ's I have been wrong ?
(Im familiar with the OLD SCJ's) but I thought the NEW CJ's were also called SCJ's ? Is this correct ?
The 2010 CJ ? (not SCJ ?) will be able to run across several classes
The 2008 had enough HP added it broke to AA only ?
But the 2010 with all the different combos announced at PRI will be able to run (F?) across up ?
I guess what I meant by SCJ was really CJ ?
What is an SCJ then (other than the obvious originals ?)
Cheers
Chris
Originally Posted by CBS View Post
Hey Chris,
Old 01-31-2010, 10:52 AM   #5
lstanford
Liked 134 Times in 32 Posts
The 2010 Mustang has two available engines, and three available transmissions for the 50 car build. The standard motor is an iron block, aluminum head engine rated at 425 HP available with a Liberty trans. or C4 auto. The optional aluminum block and head engine is rated at 475 HP and is available with the Liberty or a 2 SPD " Fordomatic". The 475 HP is OK'd for S/S only. The 425 HP is OK for Stock or S/S. The cars are very trick and come with two different axle ratios and even different size slicks depending on your motor and trans combination, Aeromotive fuel cell and pump, Strange 4 wheel discs, custom headers, Biondo launch control and the list goes on. No OEM has ever built a factory race car with this much thought put into it. I know you MOPAR racers love your cars but after seeing both cars, I think the Mustang blows the MOPAR away! The difference is because Ford has real drag racers helping to engineer and test their car and it is complete when you buy it. Put gas in it. check the tires and go racing. Ford makes two kinds of Hybrids, this one burns gas and rubber. Ok, now its time for bitching and complaining.
lstanford is offline   Reply With Quote
Old 01-31-2010, 11:07 AM   #6
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
[ Ok, now its time for bitching and complaining.[/QUOTE]
You said a mouthfull there my friend!!!
Mack Reeves
2377 STOCK & SUPER STOCK
Old 01-31-2010, 12:25 PM   #7
magnumv8
To make FECARMEN's post a little clearer....Ford is actually building 2 Different mustangs at the same time on the same line....the 2010 model Cobra Jet and the 2010 Super Cobra Jet.....the standard Cobra Jet is still the stocker everyone is familiar with and the SCJ is the NEW Super Stocker built for SS/CA...SS/C.....with the 8.50 spec cages, yes, Ford is expecting to break into the 8's.....
What took me by surprise was the NEW trans choice.....the 2 speed AUTO based on a C4......
http://www.stangtv.com/forum/followi...-jet-6381.html
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 01-31-2010, 12:15 PM   #8
Ok, NOW I know what you are talking about, the motor announced at PRI that was SS only, GOTCHA....
So apparently reffering to the Cobra Jets as Super Cobra Jets was just plain wrong on my part....check.
Yeah, I know the cars are "trick" no doubt and usually someone who copies someone elses plan does better , its a fact.
The fact Ma Mopar took forever after announcing them to get them to the track and in the meantime Ford decided to follow suit.
The Funny thing is the Guy who Built the Prototype CJs and Dodge Drag Paks has a CJ and WANTS a DP because he thinks they have more potential.....just something to think about......
The costing works out the same and at 7?k the Mustang is one hell of a piece of Machinery, take and add the other 20k that it needs to be competitive and youre at the same price as a built up DP. And I dont know as much as I should about them, my HOPE (and it may be a pipedream) is Many will never see the track, and some that do will only be raced out of the box, those I think we can take by early year.......My HOPE is many get Mothballed for investments They guys who have torn em all down and done the extra work....well those guys are pointing a .45 at us and were pointing back a .38, I guess well just have to hope they are poor shots meanwhile well work on our marksmanship
They are sweet cars....had we not already been on the list for a DP or able to get one, we would have ended up with a CJ...even if we had to clone it.
We LOVE Mopars but were pretty mercenary about performace, the best gets our attention pretty quick....dosent mean we would abandon Mopars for the Colletor/Drivers we have nothing is cooler, but Heavy Weapons is Heavy Weapons.
