Liked 5 Times in 3 Posts
Ok guys HELP! My buddy Galuk has an 80 Malibu & the drivers door will not open! When you pick-up on the handle it feels as though nothing is hooked to it? The inside handle is the same way....I would just pull the panel but with the roll bar you can't get it off with the door shut...so how do I / we get it open?
#2 | |
Not that its a good answer but the damage seems minimal.....cut the panel off and replace it ?
And Im half serious....if its one of the maroon velour ones should be easy to find.... The GM handles like that have a bad habbit of the pot metal going bad where the rod is, sometimes, sometimes, you can get a coat hanger down in the mechanism, but its a lot harder on a sedan (Im adduming a wagon has sedan doors) Ive opened them by accident with a slim jim in the process of trying to open them (on the same car) on the down stroke with the V end if I remeber right, as well......well......you can cut the door panel off.....might save time and frustration then the only thing you have to worry about is finding a replacment. (I had an malibu 4 dr like this, for 10 years or so I used as a parts runner/winter car, it was given to me and wouldnt die. I have / had a bad habbit of locking keys/loosing keys in it....I musta jimed it or hangered it (like a slim jim though) 100 times honest. sometimes I would pop the door though so I KNOW it can be done.) Maybe someone else knows another way....or take off the front fender, hinges, pull the door away from the front , take the panel off ? (that should get you the clearance) Quote:
#3 | |
Liked 5,125 Times in 1,953 Posts
Can you roll the window down? Keep squirting WD on the mechanism and push in and out on the door while flipping the handles. Maybe a hair dryer would help or a heat gun down behind the window.
Liked 10 Times in 6 Posts
Greg, on malibu doors the lock mechanism has to be unlocked to open the door from inside the car, if the pull up lock handle comes off ? the the only way to unlock door is with the key, my car has the pull handle`s removed and the key mechanism came off and i had to take door panel off to rehook, so the door would open, I had locked the door with key when this happenened. Tom
Tom Moock 5704 STK |
Liked 216 Times in 77 Posts
Just had a similar problem on a customers car in the shop not too long ago. We ended up replacing the latch mech. in the door. To get it open I rolled the window down then I got a small foam tipped paint brush, pulled the foam off and used it as a wedge between the window and the door frame to make a gap so I could get some light/ room in there to see. I went to the outside of the door and pushed in gently at the back edge of the door to take some of the pressure off of the striker. Then I put a piece of heavy wire a coat hanger might work too down in there with a hook on the end. first I pulled hard on the lever that unlocks the door then I pulled on the other one that comes to the inside handle. I had to give it a quick jerk a few times checking to see if it released after each try. I took several tries but we got it open.
Hope this helps Rob |
Liked 44 Times in 15 Posts
I've run into this a few times. What i did was lift up the outside handle and spray wd40 or something similiar inside the door towards the latch assy. Then lightly tap on the door with the side of your hand under the handle while working the handles and the lock. This will usually free up the stuck latch.
Call a locksmith. They can get in an armored car in seconds. (Auto parts stores sell a slim jim. I can't remember if that model is push or pull.)
