Old 01-18-2010, 09:33 AM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Re: TH350 Inlet/Outlet
njk53,
I installed the ATI fittings last night in my TH350 case and they work perfectly. NPS is not metric it is "National Pipe Straight" which is a thread that is typically used on low pressure hydraulic systems. In the ATI catalog they show these fittings on the page for the TH400, but not the 350 but they work fine. Another note, if you order the Jiffy Tite (repackaged as Russell) fittings through Jegs their pictures on the website are misleading showing both halves when you have to order each individually. My male fittings arrived Friday, so I had to go out and order the mating ends as well.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
