Old 01-14-2010, 06:22 PM   #19
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: Pick basics of new eliminator
The Q-Jet secondary blades protrude down .75" from the bottom of the base, so the spacer/restrictor needs to be at least that tall.
Holley 4150 rated at 500 cfm has 1.50' diameter throttle bores- all four.
A 600 cfm model is 1 9/16".
Holley makes an adapter intended to mount a Q-Jet or Thermo Quad on a manifold designed for Holley 4150 or 4160 (PN 17-6).
Maybe a 4 hole gasket underneath this adaptor is all that's needed for this test.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
