Old 01-12-2010, 03:30 PM   #7
Harry 6674
Default Re: Pick basics of new eliminator
Originally Posted by Evan Smith View Post
Easy
• Current Stock cars as they relate to body, suspension and tires
Two engine options Big-Block and Small-Block (all makes)
• Big-block and small block class with CID limit (say 480 BB and 370 SB). Assign two weight breaks for big- and small-blocks.
• List of approved heads weight break for true inline valves
• Make common intake/exhaust valve rule
• BB .600-inch lift, SB .500-inch lift, solid roller for both
• flat-top pistons
• Big-Block: limit induction to 750 cfm carb or similar size throttle body BB, Small-Block: 650 cfm or similar TBD Throttle body
Keep the induction small since that is what limits hp
Pro-tree Heads up only, runaway combos get a weight penalty.
Sounds good. Alot cheaper than the current setups and no shoe polish.
Harry 6674 is offline   Reply With Quote
